Introduction: MBAR-2 Additions
Here is a collection of optional additions to the MBAR-2. This includes:
-Vertical grip (Also works for MAR, MAR-2, and MBAR)
-Bayonet (Also can work on the MSAU)
-Bi-pod
-Grenade launcher (Pull trigger and lever trigger)
MBAR-2 Instructable
More Instructables by me.
The images show the additions on the MBAR-2.
Image 1: Bayonet and vertical grip
Images 2-3: Bi-pod
Images 4-5: Grenade launcher
Step 1: Front Grip
Much explanation should not be neccessary. Make as shown in the first image and then attach as shown in the second image to the gun.
Step 2: Bayonet
Image 1: Make 2 of these.
Image 2: Make 1 of this.
Image 3: Add white rods where indicated.
Image 4: Place the part so the white rods go through the connectors as shown.
Image 5: Cover with the last part as shown.
Image 6: Connect to the rail near the end of the barrel as shown.
Step 3: Bi-pod
Follow the images:
Image 2: And 2 of these as well.
Image 3: Connect them together so you get these.
Image 4: Now add white rods to a white connector as shown.
Image 5: Add green connectors and make a part so it looks like in the image.
Image 6: Cover with a white connector.
Image 7: Attach blue rods to the green connectors as shown.
Image 8: Add red connectors here.
Image 9: And on the reverse side.
Image 10: Attach the hinge part ot the legs as shown.
Image 11: Attach bi-pod to the gun as shown.
Image 12: When not in use and folded the Y-clips on the legs are attached to the rail as shown here.
Image 13: Bi-pod being used.
Step 4: Grenade Launcher: Launcher
Follow the images:
Image 1: Make these. The rods are blue.
Image 2: Build onto that so it looks like so. Notice the white rods.
Image 3: Add blue spacers and red rods with gray connectors on both sides.
Image 4: Build on so it looks like so. Nearly the same as before but with 3D connectors.
Image 5: Add green rod and white rod with tan clip.
Image 6: Add orange connector.
For a Pull Trigger:
Images 7-8: Make this part.
For a Lever Trigger:
Image 9: Make this. Notice all the white rods.
Image 10: Add on hinge, red/gray connector, and blue spacers as shown.
Image 11: Build onto that to get this.
Assembling the Components:
Image 12: Pull trigger attached.
Image 13: Lever trigger attached.
Image 14: Grenade launcher attached to gun's rails.
Step 5: Grenade Launcher: Grenade
Follow the images:
Image 1: Make this. Notice how the rubberband is placed and that the orange connector is twisted.
Image 2: Add gray spacers (can be blue as well) and place a gray connector at the end as shown.
Step 6: Grenade Launcher: Use
To load follow the images:
Image 1: Hook the rubber band on the tips of the grenade launcher.
Images 2-5: Hook the rubber band on the ammo's yellow connector as shown, pull back and insert in between the white connectors and push the white rod up to lock it in place.
To Fire:
Pull the trigger if pull trigger. If lever trigger, push upwards in the dirrection of the barrel.
Step 7: Warning!!!
Warning- These K'nex may cause harm or injury if misused. Do not point it at people. I am not responsible for damage, injury, or death caused by this instructable. Do not treat this just as a toy but as a real, dangerous weapon.
15 Comments
12 years ago on Step 3
very clever how the bipod actually locks into place..
Reply 12 years ago on Step 3
Thanks.
12 years ago on Introduction
None of these addons are necessary. Neither is the warning.
Reply 12 years ago on Introduction
Necessary they are not but some people if they have build the gun and still have pieces left they may want to build on to it. Some reasons may be such as for better aiming with the bi-pod or just for the looks or psycological effect with the rest. I also believe the warning shouldn't be necessary but now people seem to lack common sense so it's better safe than sorry.
If people lack common sense, just don't put the warning in there. They totally deserve anything bad that happens to them for lack of common sense.
I also think so but the law seems to be on the people without sense's side. That's why on most things there are warning labels such as on superhero costumes which say that wearing it does not enable you to fly.
Lol...
On a packet of peanuts - warning, may contain nuts
I know. I'd assume people would be smart enough to infer that themselves. Mind you if it didn't have nuts in a pack of nuts (OK, peanuts are legumes, but aside from that...) then one might want to find out what it really is that one is about to eat.
yeah, the best harmful use for this would be hitting someone with it.
What do you mean by "it"? Are you refering to the bayonet or the gun itself in general.
both. its just a piece of plastic. wait, plural, piece'S of plastic easier to break not the bayonet so much. its smaller.
Almost anything made from K'nex would break if thrown at a brick wall at 1000 MPH. The thing is that K'nex weapons aren't used for hitting brick walls but either just for show or for fights which aren't lethal but entertaining. If it was lethal the target would die and it would cease to be all that entertaining while you spend time in prison.
there's no way YOU'RE going to throw a plastic bayonet at 1000 mph including the gun. why would you throw/shoot a bayonet/gun at a brick wall anyways? and why would i throw my airsoft gun a t a wall? or shoot it at a wall? you're arguments are completely irrelevant. and honestly, nobody mentioned lethal weaponry until you did. the best/worst airsoft guns can do is sting unless you shoot someone in the eye which is why people created a safety precaution called glasses. or if you get shot in the crotch but that wouldn't hurt at all unless you were really stupid enough to have a naked airsoft shoot thingy.
Maybe my arguements are irrelevent but that is because of you spelling and grammar which is in my opinion a total failure. I also get the feeling that you haven't made a K'nex gun in your life nor have made anything from K'nex and therefor do not have the experience to know if my K'nex guns are good or bad. Now if you want to post comments on my Instructables, how about first making the instructable and maybe some other K'nex guns so you could finally have an opinion which is actually worth something. Now if you want to comment and argue with me, send it in a private message after spell checking the message, but not here on my Instructables. If you post any more comments on my Instructables which I deem of having no cause of being here, meaning that you haven't made the Instructable and are commenting whether it is good or not, I will most likely flag it.
Comment by sending me a private message! Not by replying below!
kool
