Introduction: MHG-1
This is my MHG-1 (Masterdude Hand Gun model 1). It is not one of my semi-auto's, but a gun which uses a new trigger system which I have not used before (you asked for it you got it). The ammo is handle fed and it's firing pin powered so I could make it more compact. As you probably have noticed (first thing probably) is that it seems to have a hand guard, which it does, but it is also part of a new trigger I designed. Even if my previous guns seemed uninnovative, this gun should make it that you can't say that I don't innovate and do new stuff anymore.
More Instructables by Me
Pros:
Pros:
- True trigger
- Handle fed magazine
- Large ammo (well I like it)
- Doesn't use too many pieces
- Or rubberbands
- Trigger is a hand guard
- Loading ammo can be tricky
- Trigger can seem wierd to use at first
Step 1: Components
Make the following in the quantities stated. Each component is assigned a letter for further reference:
Image 1: Make 2. A
Image 2: Make 2. B
Image 3: Make 2. C
Image 4: Make 1. D
Image 5: Make 1. E
Image 6: Make 3. F
Image 7: Make 1. G
Image 8: Make 1. H
Image 9: Make 1. I
Image 10: Make 1. J
Image 11: Make 2. K
Image 12: Make 1. L
Image 1: Make 2. A
Image 2: Make 2. B
Image 3: Make 2. C
Image 4: Make 1. D
Image 5: Make 1. E
Image 6: Make 3. F
Image 7: Make 1. G
Image 8: Make 1. H
Image 9: Make 1. I
Image 10: Make 1. J
Image 11: Make 2. K
Image 12: Make 1. L
Step 2: Assembly
Follow the instructions and images:
Image 1: Add blue and white rods to Parts A & B.
Image 2: Add Parts C, F, & K and white rods.
Image 3: Add Parts D, E, F, G, H, I, & J, and blue spacers and gray connectors.
Image 4: Add Parts C, F, & K.
Image 5: Add Parts A & B, and a tan clip.
Image 6: On reverse side add a metallic blue clip and gray connector.
Step 3: Operation
Load the ammo (Image 1) into the mag (handle), and then insert the ammo pusher (Part L). Then add the rubberbands connecting to the ammo pusher and one to the firing pin as well. Then pull back the firing pin to cock the gun, and then pull the trigger to shoot (may take some time getting used to the trigger). Repeat as needed.
Warning- This may cause harm or injury if misused. Do not point it at people. I am not responsible for damage, injury, or death caused by this instructable. Always treated it as armed.
