MIDI Handpan With 19 Tonefields on Upper and Down Side...
Intro: MIDI Handpan With 19 Tonefields on Upper and Down Side...
Introduction
This is a tutorial of my custom made MIDI handpan with 19 volume sensitive tonefields, Plug'n Play USB capability, and a lot of easy to use parameters for adjusting the pads for your individual needs. It's not a design award winning model ;) but it perfectly fits to my needs in practicing handpan playing at home.
The building process is easy, but it takes some time. (Due to Corona lock down I had enough time in the last months to make this device). If you wanna make your own model and you have fun in cutting, sawing, a little soldering, then probably this is a project for you.
You don't need any Arduino programming knowledge, because I used a standard drum trigger interface, that I mounted inside the base. The total costs for the materials are about 150.- Euro.
The usage of such a standard Trigger module (in my case an Alesis Drum Trigger I/O that I got second hand for 90.- Euros) has some important advantages, that I will describe in step XXX in this tutorial.
To play this instrument you need a PC or Mac, a DAW or a VST Player for free and some headphones or Speakers.
A few words why I did this and how I started by making a prototype with only 8+1 tonefields
I am a handpan player and one day I dreamed to have a MIDI-device with several tonefields, on which I can play similar to the playing techniques on Steelpans.
My intention was:
+ To have a practicing pad
+ To check out different scales before buying a real steelpan
+ The possibility to play calm via headphones
+ Using different soundfiles like Piano-Samples, Drumkits, Synths and so on in my DAW
I searched the web and found a site of a guy from Chile, who made a very nice electronic MIDI Handpan out of a really beautiful wooden body. But because my skills in shaping wood are not so good and so are also my electronic and programming skills, I began to look for alternative materials and techniques.
Months later deep in the night on the way to my home I found the right material standing very lonely near the street..... it was an old foam mattrass in a area of trash!! Now the idea for that device was born :)
The foam has really good characteristics: it is easy to cut with a knife for putting it into the right shape, it is lightweight and the most important fact: the material muffles the mechanical trigger impulse from one pad to the other pads, so a finger hit on one trigger will only trigger this pad and not the others.
For the drum pads I decided to use 4 mm Plywood after several experiments with different materials.
My first idea was the traditional layout with 8 Tonefields in the circle and one in the middle called "Ding". In this version the drum trigger interface was outside the whole thing, standing beside on a table connected via a 15-pin cable.
In the middle of the building process I got the idea, why not putting the interface inside the instrument and why not use all 19 available inputs? Yeah! So the instrument grew....
In this instructable I will present you both versions
Go through every step until you reach step "If you want the faster solution". This step will bring you to the version with tonefields only on the upper side. The steps after that show, how to build the version with bottom notes and inside trigger device.
So now it's time to start! :)
Feel free to ask me, it can take some days till I will answer, but I am really interested in what other ideas you will have...
STEP 1: What You Will Need
List of materials:
- A drum trigger (I used the Alesis drum Trigger I/O)
- Two pieces of 10 cm foam (I used an old mattrass) with diameter about 51 cm
- Plywood 4 mm for 9 or 19 pads of 10,5 cm diameter. Important note: Check out the quality before buying. I saw some pieces and found some big holes inside. Or I had some pieces of wood that were not flat enough or a kind of wood that was too soft. The harder the wood, the better it will transmit the knocking impulse to the piezo while playing, especially when you hit the edge areasof the tone field
- Plywood 8 mm for the plate in the middle with diameter a little bigger than your foam (about 53 cm)
- Some meters of thin isolated flexible cable, I took blue for "ground" and orange for "hot"
- 2 small standard stripboards
- 10 Stereo headphone jacks (0,99 Euro)
- Duck tape
You will need these extra materials for the smaller version and EXTERNAL drum trigger:
- The number of piezos that you wanna have in the end plus some more (Important information about these Piezos and why you should have some more, go to step "Mounting the piezos")
- 15 pin Sub-D cable, 3 meters with one male and one female end
You will need these extra materials for the version WITH bottom notes and drum trigger INSIDE:
- 4 pieces of 20 mm wooden log, about 6 cm long
- The number of piezos that you wanna have in the end plus some more (Important information about these Piezos and why you should have some more go to step "Mounting the piezos")
- 2 pieces of 16-pin flat cable, about 30 cm each
- 2 male 16 pin print connectors (Try to figure out the photo, what I mean, in german it's called "Pfostenstecker")
- 4 female 16 pin print connectors (Pfostenbuchse)
- 2 metal pieces + 4 screws + 2 female screws to mount the drum module
- 2 angled metal pieces + 2 screws + 2 female screws for to mount the display
- 3 meter USB-cable with A and B connector end
Tools:
- A non permanent pen
- Ruler, yardstick
- Jigsaw and when you have: a table for sawing circles
- Cyanoacrylate adhesive(Sekundenkleber)
- Universal glue
- Soldering bolt and tin solder
- Electric drill
- Sandpaper
- Boxcutter
- Big bread knife with serrated blade
- Big scissors (those big ones for cutting paper are good), it should fit well in your hands because you will use this for some hours...
- 20 mm metal tube to build a circular blade for cutting out holes in the foam
- Plier
- A small bench wise
STEP 2: Cutting the Foam Base
- Draw a circle on the mattress by using a non-permanent pencil . I used a diameter about 51 cm
- Take a big knife with a serrated blade (e.g. a bread knife)
- Begin to cut the circle (take care of your fingers!) Try to give only a minimum pressure to the knife
- The result should look like a big cheese wheel
- Now you have to decide if you wanna have 8 or 9 tonefields in the ring area
- Because I decided to get 8 fields I made 3 even lines on the upper side (see photo). So I got 8 markers for the next steps
- Now start with one of the 8 or 9 fields. Take the scissors and cut off all material in that way, that you will get 8 or 9 similar flat areas. That job takes a little time
- Let a 2 cm rim at the bottom side
STEP 3: Sawing the Tone Fields
Some words about the position of the tonefields:
Although the muffling characteristic of the foam prevents knocking impulse that you give on one tonefield from triggering a neighbouring tonefield, you should have a minimum space between the tonefileds. I checked out that 4 - 5 cm space is enough. In the upper area some of them have only 2 cm space and therefore I have some triggering of a neighbouring field in some playing situations.
BUT: When you are playing real steelpans you will recognize, that playing on one tonefield is always triggering other tonefields. That's a natural characteristic of steelpans. The most scales of steelpans are designed in a way, that the sound of neighbouring tonefields doesn't cause in inharmonic sound. So I think the mechanical insulation of the tonefields need not to be 100% perfect.
Now let's start sawing:
- I used a special stand for my jigsaw in that way that the saw is fixed upside down inside a plastic ground, so you can use it like a band-saw. If you have no special stand for your jigsaw you can use it also in the common way by hand. Be careful in this process!
- The blade should be a special one for sawing narrow curves, those let you saw really good circles.
- At this time you should make a decision of the numbers of tonfields you wanna have on your instrument.
- The diameter I decided was 10,5 cm for the normal sized tone fields and 7 cm for the smaller ones. For the "smiley mouth", i used 2 quarters of a circle, they are about 3,2 cm wide.
- Draw your circles on the wood and begin sawing.
- Important note: The saw will produce some splinters on one side of the wood, that's normal. On the other side you should get an exact edge
- After the sawing process begin to polish the edge of the upper side of the pads, so that they get a little bit rounded. When you later play on the instrument, the fingers will knock sometimes on this edge. Rounded edges will give you more playing comfort.
- Now you could paint the pads with colours or wax the surface.
STEP 4: Mounting the Piezos
Important Information about the piezos:
In my area (Germany) the exact type I used is EPZ-27MS44W (27 mm diameter, 4400 Hz, 200 Ohm, 21.000 pF). I am shure other models will also work properly. I took these because they are very cheap, only 0,39 Euro and they have some cables already mounted and the diameter is really big enough.
Before you buy them, I really recommend to have some more of them, the reason is:
Electrical output differs from one to another piece. Some of them produce more voltage than others. This is normal within a range of tolerance for this product. When I tried different pieces in my DAW, I noticed this difference very well. The result was a higher or a lower MIDI volume and this was really remarkable.
The solution was a simple selfmade test station!
Unfortunately I forgot to make any photos, so I try to put it into words here...
The Piezo test station:
I took a base out of 30 cm x 10 cm wood, where I mounted a kind of a „sliding board“ formed of paper which ends about 5 cm above the base. At this endpoint on the base I draw a circle of 30 mm diameter. Now I cabled one input of my drum trigger interface into two cables beside the test station. I started my DAW and zoomed very deep in track view. By pressing record I could see the volume amount of the incoming Volume data.
Now I began to test every piezo. Just by laying a piezo on the circle, clambing the two cables to the piezo and let roll a small plastic marble on the sliding board. You should always use the same level when starting the marble. Make about 5 to 10 trials per piezo to get a useful average of the volume signal. When I evaluated a aproximate average of the volume data, I devided all tested piezos into 3 groups: low, middle and high. For my project I now used the piezos of only one of these 3 groups. The exact amount of output voltage is not important, but the difference between the different piezos.
Although the Midi drum trigger interface gives the opportunity to adjust the relation between incoming voltage and MIDI volume output signal, it is important to seperate out those piezos that give a very low or a very high voltage.
Because the piezos are really cheap I buyed about 40 pieces. I am shure I will make other MIDI devices one day...
So now we gonna glue the piezos onto the pads:
- Use a very fine piece of sandpaper and make the surface of the piezo a little bit rough. Be sure to use the right side where no cables are mounted!
- And do the same in the middle of the wooden pads.
- Now use some drops of cyanacrylate adhesive and glue the piezos on the surface.
- Press with your fingers for 30 seconds (be careful to get no glue onto your skin).
- Don't use a bench wise (Schraubstock), it could damage the piezo!
- Now take 2 pieces of thin cable about 25 - 30 cm long and solder them.
- After that fix the cables with tape.
- Do that with everysingle tone field
STEP 5: Preparing the Ground for the Tonefields
- Be sure that the ground for each tonefield is nearly flat
- Indicate a circle for the trigger pad on the base. Use one of the pads as a template (When you cut the pads by hand use exactly the one pad you will put in a this area, otherwise there could be differences).
- Then draw a second circle inside every circle with a diameter about 6 cm.
- First cut along the inner circle about 15 mm deep and remove all the foam inside this area so that you will get a pit.
- Then cut along the outer circle 5-6 mm deep (it is 1-2 mm deeper than the thickness of the wood). Again remove the material in that way, that you will get a flat ring. I recommend to do this accurate. The trigger pad will be fixed later on this ring area, therefore it must be really flat.
- By the way: This step took me a lot of time.....
- Now we need a hole for the cables in every space. I used a piece of an old metal pipe for cutting this hole like a drill.
- For this I sharpened one side of the 20 mm pipe with sandpaper
- Take this "round knife" to cut a hole into each place by drilling it
Last step: On the downside of your foam make a round sink about 20 cm diameter and 3 cm deep. Later this will be the space for all the cables coming together.
STEP 6: Sawing the Middle Board ***
SORRY, this instructable is not ready yet!
Some steps are missing right now.
If you are interested to have the next steps, I will explain them to you.
The reason is simple:
It takes a lot of time to recapitulate all the steps to build this instructable.
I don't wanna make this work only for digital machines in the web,
but I would make it for you!
So let me know If I should continue this instructable and write some comment here...
STEP 7: Drill 4 Holes in the Upper Foam
STEP 8: Mounting the Tonefields ***
Before mounting the tonefields it's time to decide which colour the pads should have or if you just wanna polish its surface with wax. And now you can remove the marks that you painted on the foam. If you think about painting the foam, be very careful. Most paint is aggressive towards foam. The risk of loosing texture is very high. I made some experiments. The loose of texture can be a very slow process. The material will loose it's elasticity and in the end it will crumble away.
I tried some water resistant pens (In Germany e.g. "Edding"). With the red and the black one I got a result that didn't really damage the foam. But I decides to let it in "natural" style.
Now let's mount the pads on the base:
- Before you mount one pad, make a quick test by clambing it to one input of your drum module, to see if cables are mounted exactly
- When it works well, take this pad and lay it's cables through the hole in the foam.
- From the other side pull the cables tightly, so that the pad will almost fit into it's position
- Pull back the pad a little bit, only so so that you can put glue onto the back side
- Put about 8 - 10 drops of universal glue round the rim of the pad. But don't spread it, let the drop laying on the wood. And do not give any glue onto the edge of the wood (In the case of a broken cable or if a piezo gets defect in future, you can remove a pad more easily).
- Now again pull the cables from the other side and move the pad in it's right position
- Place the foam body in a way, that you can put some weight onto the pad. Use a small food conserve tin. And let the glue get dry for 2 hours. Only glue one pad at a time.
STEP 9: If You Want the Faster Solution....
If you wanna have the quick solution and end here go along this page:
- Make simple cuts from each small hole to that sink. Here you can store the cable easily
- Cut the 15 pin connector
- Now take a strip board and solder every orange cable to one line.Because there are 2 rows with 8 pins you must make a cut on the board in the middle to interrupt the electrical line.
- See on the pictures how I soldered all the cables. Each orange cable enters one pin of the connector and the blue ones come all together into the one pin "ground"
- Take a saw and make a simple cover out of wood for this electrical area. Make it a little bit bigger than the sink, so that it will clamp inside the foam. Saw a hole into he middle, so that the connector can look out of the cover
- Now the upper part of your instrument is ready and in the next step we prepare a connector cable
STEP 10: Connecting Your Instrument to the External Drum Trigger
STEP 11: If You Want the Full Potential Instrument
If you wanna the professional version with the maximum amount of tonefields go along here
- First make a round sink into the downside of the foam, about 20 cm diameter. This will be the space for all the cables coming together.
- Now take a strip board and solder one of the 16 pin male print connectors. Because there are 2 rows with 8 pins you must make a cut on the board in the middle to interrupt the electrical line.
- Take a saw and make a simple cover out of wood for this electrical area. Make it a little bit bigger than the sink, so that it will clamp slightly inside the foam.
- Saw a hole into the middle for the connector to look out of the cover
STEP 12: Making a Flat Connection for the Upper Part
If you are really insterested in doing the next steps, pleas write an email to me
I ended here because I don't know how much interest do have people for this.
It is a matter of time .... ;)
So feel free and write an email, it could take some days, then a I will answer and give you the full instructable!
STEP 13: Peparing the Drum Trigger Module
STEP 14: Put the Trigger Module Inside the Instrument
STEP 15: ...Some Steps Later...
STEP 16: The Final Instrument
Here's a small video of the instrument:
https://www.youtube.com/watch?v=0q0imb2iiCo&t=23s
14 Comments
Deepsoul77 1 year ago
https://youtu.be/0q0imb2iiCo
PanCake2Me 2 years ago
Deepsoul77 2 years ago
Seems also a nice solution what you did.
Do you have a video where you play it?
Is it a VST instrument that you trigger? And which one?
At the moment I spend my time into another project:
the first part of it i a trigger board that goes round one of my real handpans, so i can play handpan and have ten trigger pads available at the same time :)
I finished my first prototype now and the flow between real pan and trigger pad is quite good.
The second part will be 4 or 5 foot pedals for triggering pad sounds or bass textures with my feet at the same time....
Similar to my MIDI-handpan I use wooden circles, piezos and a second Alesis I/O. In the Alesis I made different note mappings. I.e. for playing the same notes like the RAV/handpan but one octave lower, or one mapping for a split instrument with 5 bassy texture notes and 5 drum samples (I think like you did in your video?)
It makes fun, but it really takes time to learn playing on it! :)
seamster 3 years ago
oaziris 3 years ago
Deepsoul77 3 years ago
Until now I didn't find inspiration and time for to make a good looking video...
But now when I know that someone is waiting for a video perhaps that will give me a boost to do so ;)
When I made a video, I will link it here..
