MINI NASA INGENUITY HELICOPTER
Intro: MINI NASA INGENUITY HELICOPTER
Hey guys, in this instructable I will be showing you how to make a simple small 3d printed or cardboard version of NASA's helicopter, called Ingenuity, which recently made history on Mars as the first spacecraft to successfully fly with rotors as the method of propulsion. This project is great for all ages and lets you own a small piece of history!
STEP 1: Dissassemble Toy Helicopter
Use a small screwdriver to remove the 4 screws from the body of the toy.
Carefully remove the electronics and try not to put too much pressure on any of the thin wires.
Set aside until the body is ready for the final assembly.
STEP 2: 3D Printing the Body and Feet
STEP 3: ...or Make Cardboard Body
Print out the attached flat pattern on standard 8.5"x11" paper. Be sure to set the scale to 100% or it will not be correct. You can alway use a caliper to double check the dimensions called out on the page as the model is drawn at 1:1 scale.
STEP 4: Apply Metallic Film and Attach Legs
This step is optional but if you want to use the film, simply cut a piece of film to 5"x5".
Use spray adhesive to coat the film and the body. Carefully begin scraping with a piece of cardboard to smooth the bubbles out.
Use scissors to trim excess film from the edges and fold any remaining film.
Puncture the film with the brass rods, cut to 3", and insert them into the body. If you are using the cardboard version, you will need to use hot glue on the inside to hold them in place. If you are using the 3d printed body and the legs are a little loose, just apply a small amount of glue on the ends of the rods and press them back in place.
STEP 5: Final Assembly
If your body is covered with film, you will need to make a small slit along the opening of the body to get the electronics in.
Tuck everything neatly inside the body with the usb connector facing down. Use a small amount of hot glue on the inside to keep the electronics from ejecting during a crash.
STEP 6: Off to Mars!
That's it! Now go build your own little fleet of Mars Helicopters!
Let me know if you have any questions. Thank you for taking the time to read my instructable. If you liked it, please consider voting for the contests in which I've entered it into.
14 Comments
birdsoft 2 years ago
armadillozenith 3 years ago
(Great way to engage young people with latest space developments and STEAM subjects.)
Re the body rotating, my first thought was that - assuming your rotors are identical, angled and geared equally - I'd check for any slight difference of mass in their respective rotating driveshafts/geartrains, and seek to balance that out.
Proto G 3 years ago
Techhlp 3 years ago
Your selection is far more suitable for gripping uncharted terrain and is a closer match to those used in the fleet of Mars rovers.
Proto G 3 years ago
Nikolaos Babetas 3 years ago
Proto G 3 years ago
Witheredboi 3 years ago
Proto G 3 years ago
cantarosabela 3 years ago
Proto G 3 years ago
chi239 3 years ago
randofo 3 years ago
Proto G 3 years ago
