MINI POCKET CRAFT SET!!!
Intro: MINI POCKET CRAFT SET!!!
Ever just needed that little rough bit smoothed out, had to cut something but had nothing near you to do the job or your bootlaces are too long and you need them shortened? Well this here is the perfect thing for you! Its quick to make, very light and unnoticeable when in your pocket and does its job in the best way possible.
ENJOY AND FEEL FREE TO ASK ANY QUESTIONS OR COMMENT
STEP 1: What You Will Need
You will need:
- Scissors
- 2 small magnets (this will be for the case which is optional)
- 1/2 centimeter dowel
- Mini craft set knives
- Duct tape
- Craft knife
STEP 2: Cutting the Dowel to Length, Splitting It and Fastening the Blade
First you will need to cut your dowel roughly and inch long. Then split your little newly-made handle length-wise to about 1/2 way down. Now you can push your selected blade into the slot and tape in together with duct tape until its held firm.
STEP 3: Making the Case (optional and Recommended)
Next you will have to find 2 small, flat magnets about an inch or more wide. Make sure they can go face-to-face and don't reject each other. Now simply duct tape them together as well as on the bottom and you now have a light weight case that will hold your spare blades firmly in tight using magnetic force.
GOOD LUCK AND CHECK MY OTHER INSTRUTABLE'S!!!
2 Comments
DEEJAY642 8 years ago
what do you mean. It was only listed 12 hours ago
Jake_Makes 8 years ago
