Introduction: MMBTH81 Transistor: a Miniature Amplifier Circuit
About: Eiyu | Electronic Components Specialist Providing expert insight in sourcing, modules, and supply chain strategy at Eiyu—a top distributor of components from 1,000+ global brands.
Create a small audio amplifier circuit that can amplify low-level audio signals from an audio source (like a smartphone or an MP3 player) using the MMBTH81, which is a small-signal NPN transistor.
  1. MMBTH81 NPN Transistor
  2. 1kΩ Resistor (R1)
  3. 10kΩ Resistor (R2)
  4. 100µF Capacitor (C1)
  5. 10µF Capacitor (C2)
  6. Small Speaker (8Ω)
  7. Audio Source (like a smartphone or MP3 player)
  8. 9V Battery or power supply
  9. Breadboard and connecting wires
Step 1: Input Signal
The low-level audio signal from an audio source is fed into the base of the MMBTH81 via the 10kΩ resistor (R2)
Step 2: Biasing
The 1kΩ resistor (R1) helps to set the base current. This biasing is crucial for the transistor to operate in its active region and properly amplify the audio signal
Step 3: Capacitors
  1. The 100µF capacitor (C1) blocks any DC component from the input audio signal, allowing only the AC audio signal to pass into the base of the transistor.
  2. The 10µF capacitor (C2) allows the amplified audio output to couple to the speaker while also blocking DC signals.
Step 4: Speaker
The amplified audio signal is delivered to the speaker, allowing you to hear the audio output.
How It Works:
  1. Signal Amplification: The MMBTH81 transistor amplifies the small input audio signal. The output at the collector is a larger version of the input signal.
  2. Speaker Output: The amplified signal is coupled through C2, allowing it to drive the speaker, producing sound.
Applications:
  1. DIY audio amplifiers
  2. Small guitar amplifiers
  3. Boosting sound from low-power devices
Notes:
  1. Adjust resistor values if you need different gain levels or to match specific input/output levels.
  2. Ensure that the power supply voltage is appropriate for the transistor ratings, typically 9V is safe for the MMBTH81.
