Introduction: MMP-1
This is my 15th K'nex gun I'ble and 30th I'ble altogether. This is my MMP-1 (Masterdude Machine Pistol model 1). It does not use my semi-auto mechanism but uses one based off of my MAR-4 mech.
More Instructables by Me
Pros:
Pros:
- Slide action
- Removable magazine
- True trigger
- Trigger guard
- Compact
- Relatively low piece count
- Looks?
- Range/Power not all that awesome
- Not semi-auto
Step 1: Main Body: Components
Make the following in the quantities stated. Each component is assigned a letter for further reference:
Image 1: Make 1. A
Image 2: Make 2. B
Image 3: Make 2. C
Image 4: Make 3. D
Image 5: Make 1. E
Image 6: Make 1. F
Image 7: Make 1. G
Image 8: Make 1. H
Image 9: Make 1. I
Image 10: Make 1. J
Image 11: Make 1. K
Image 1: Make 1. A
Image 2: Make 2. B
Image 3: Make 2. C
Image 4: Make 3. D
Image 5: Make 1. E
Image 6: Make 1. F
Image 7: Make 1. G
Image 8: Make 1. H
Image 9: Make 1. I
Image 10: Make 1. J
Image 11: Make 1. K
Step 2: Main Body: Assembly
Follow the instructions and images:
Image 1: Add white and blue rods to A and B.
Image 2: Add C and D, and more white and blue rods as well as gray and red connectors.
Image 3: Add D, E, F, G, H, I, and J, and 2 blue spacers.
Image 4: Add C and D, and gray and red connectors.
Image 5: Add B and K.
Step 3: Magazine
First make 2 of each in the first 3 images, 4 of the 4th, and 1 of each from images 5 and 6.
Image 7: Add white rods as shown.
Image 8: Add/connect the other parts as shown.
Image 9: Cover with the last pieces to finish.
Note: Image 6 is the pin which holds the ammo back until the mag is inserted in the gun. It is not shown until the last step.
Step 4: Operation
After putting the rubberband on a mag as shown in Image 1, insert the ammo (gray connectors, Image 2) and put the pin in to hold them in place. Then add the rubberbands onto the gun as in Image 3. Then insert the mag into the gun as shown and pull out the mag pin. now pull back the slide as in Image 4, and pull the trigger to fire. Then repeat pulling the slide back and pulling the trigger as needed.
Warning- This may cause harm or injury if misused. Do not point it at people. I am not responsible for damage, injury, or death caused by this instructable. Always treated it as armed.
