Introduction: MODIFIED MOUSE RUNS ON LITHIUM ION CELL PHONE BATTERY
At one point I mused that it would be nice to be able to power the mice with the BL-5C Lithium Ion batteries that power my cell phone. They recharge quickly and hold a lot of current. Only problem is they are 3.7 volt batteries and the mice are designed to run on a couple of AA's in series... 3 volts. I wondered if the extra .7 volt would be a problem. One way to find out. A couple of jumpers later, I had my answer... the mouse seemed quite happy with 3.7 volts.
The hard part was finding a way to stuff the battery inside the mouse. You have to chop a lot of the battery compartment plastic out, remove the springs, and install a connector assembly that will match up with the BL-5C terminals (if you want it to be removable, more on that later).
Step 1: Not a Step, Just a Pic
I also installed a small slide switch with which I can turn the mouse off to conserve battery power.
Step 2: Clearing the Way
You must take great care not to remove plastic which supports the right and left mouse buttons... nor any that affects operation of the mouse wheel.
Look it over real good before you start chopping!
It might even turn out that the mouse you want to modify cannot accomodate this size and shape of battery and remain functional.
Step 3: The Connector
Only two of the finger spring contacts are actually used, the others I bent slightly so they are flatter and don't protrude.
Step 4: Making Contact
This requires hit-and-run soldering. You have to have the iron just the right temperature so you can get the solder on quickly and remove the iron before you melt the battery case.
SAFETY NOTE: Lithium ion batteries are dangerous critters. They don't take kindly to abuse. These batteries have a safety device built into them to prevent overcharging or over-current (short circuited) which ends up disabling the battery, but that's better than the alternative which the industry euphamistically calls "venting with flame". When even the euphamism sounds scarey, you're dealing with some serious doo-doo. Don't do anything to one of these batteries that can pierce it, overheat it, or otherwise tick it off.
Step 5:
In retrospect, perhaps I could have left that spring in there.
Step 6:
I made this modification about a year ago, before I had a simple way to recharge a Lithium Ion battery ... if it were not removable from the mouse. I have just been using my cell phone to recharge the battery when it needed it, which is about every two weeks or so. (I never remember to turn the mouse off at night with the switch.) I have several of the phone batteries, so I can just slip a charged battery in and put the depleted battery in the phone for charging in just a few seconds.
Step 7:
It is a simple matter to clip on a couple of jumper cables to charge a battery, even if it were still in a mouse.
Making and mounting the battery contact assembly in the mouse was probably the hardest part of the project and required a lot of fiddling and adjustment. The whole mess could be avoided by hard wiring the battery and just using one of these chargers, but you couldn't use the mouse while you wait for it to charge.
This charger cost me $1.50 US with free shipping! from an eBay auction and it works like a champ.
I've been powering this mouse with BL-5C's for over a year now and the over-voltage has produced no adverse effects, so I decided to share it with the world.
Davetech
