Introduction: MODIFY YOUR HEXBUG SPIDER WITH WASTE MATERIAL.
About: Jack of all trades, master of none but still better than a master of one.
here I'm introducing a fun way to modify your HEXBUG SPIDER with waste material.
Step 1: USEFUL/PLAYFUL HEXBUG SPIDER
I know that you might be thinking that the hexbug spider is already a great toy ,but in this instructable you can learn to modify that great toy into more useful and playful toy than it was before.
For example :- you can make different kinds of attachments to it, make it do some cleaning around your play area with it or even clean water spills and even you can use it to bring small things to you with it .
Step 2: TOOLS AND MATERIALS
TOOLS :-
hot glue gun
scale
cutter
marker
MATERIAL :-
hexbug spider ( http://www.amazon.com/HEXBUG-Hexbug-Spider-colors-... )
foam (polyethylene sheet)
wooden sticks
masking tape
glue
pen
Step 3: MAKING THE HEAD GEAR
Measure the foam and mark it up to 1 inch . After that draw a square and cut it out.
Now take one stick and measure 5 inches on it and cut it . After that insert it in the middle of the foam cube.
Step 4: HEADGEAR ATTACHED TO HEXBUG SPIDER
Now glue the stick and the foam together. And glue the headgear (foam cube) in the middle ,top of the hexbug spider.
Step 5: MAKING THE ATTACHMENTS
Now make a rectangle . length = 5 inches , breadth = 2 inches and cut it out.
Mark the rectangle as shown in picture number 3 like a trapezium and cut it out.As shown in picture number 4.
Now take another stick and mark 4 inches on it . After that cut it and glue it in the middle of the attachment.
Step 6: MAKING THE HOLDER OF THE ATTACHMENT
Now dismantle the pen and mark 1 inch on its body as shown in picture 1. After that cut out the marked area and with the help of the cutter cut off a strip making a space .As shown in the picture number 3.
Now when you are done cutting the body of the pen glue that piece to the headgear which is already glued on to the hexbug spider.
Warning :- don't glue the piece where you had made the cut in between of the pen body . glue the area where there is no cut like shown in picture number 4.
Step 7: THE CLIPPER ATTACHMENT
Now take a piece of foam and insert it on the stick as shown in picture 1 to 3.
Now tape the foam tightly to the stick.And you are done.All you have to do is attach the stick to the clipper which is attached to the hexbug spider.
Step 8: DEMO
you can also make different types of attachments as per your own designs.
here in the following video you can see the working demo of the modified hexbug spider.If you have any questions please leave in comments.
THANK YOU FOR WATCHING THIS INSTRUCTABLE.
