Introduction: MOPED INLINE FUEL FILTER
Lots of mopeds have rust or gunk in the gas tank. This crud will find it's way into your carburetor and crud it up, causing your bike to run like crud. Nobody wants that! Fortunately there is a cheap and easy solution for this problem... thee inline fuel filter! Follow me, I'll show you how to do it.
I made it at Techshop. They have a work bay where you can work on your car, motorcycle, moped... whatever! There are 3 of them around the SF Bay Area, so it's pretty convenient. There's others around the country and they have lots of tools and workshops. Wood, Metal, Fabrics, Electronics and more. It's rad.
Check it out here: www.techshop.ws
word!
You'll need...
Some new fuel line
An inline fuel filter
A pocket knife
word!
You'll need...
Some new fuel line
A pocket knife
Step 1: Remove Old Fuel Line
Your old fuel line is probably all crudded up, lets replace it. First, turn off the fuel flow at the petcock valve. Then, pull the fuel line off from the carburetor and the petcock valve. Throw that in the garbage, because it's all yuck.
Step 2: Install New Fuel Line...
Grab your shiny new fuel line and attach 1 end to the petcock valve.
Step 3: Position Fuel Filter
Now visually position the inline fuel filter. I try to set the position so that the filter is at the lowest spot of the fuel path, so all the crud will get trapped in the filter and held there by gravity. I like gravity because it's cheap and works most of the time. Also, on most inline fuel filters there will be an arrow showing the direction that the fuel should flow. Be sure to take this into consideration when planning the position of your new filter. Don't let the filter make contact with the cylinder or other hot parts.
By the way, never reuse an old fuel filter. Never ever.
Step 4: Insert Fuel Filter
Cut the fuel line and wiggle on the new fuel filter with the arrow pointing towards the carburetor. It's usually a tight fit and may require some cursing. Cram the filter as far into the fuel line as you can, all the way if possible. You don't want that fuel line to fall off and spill gasoline onto your hot cylinder and spark plug while you're cruising, so do it right, not half-assed.
Step 5: Keep on Cursing....
Good. Now wiggle the fuel line onto the other side of the fuel filter, you're almost done. Got it? Good. Now trim off the excess fuel line and attach the final end of fuel line onto your carburetor. That should be it. woo hoo. Turn on your fuel from the petcock valve and wait a few minutes to see if there are any leaks. There shouldn't be. Your carburetor will love you for the new fuel line and inline fuel filter.
