Introduction: MQ2 Shield on PcDuino
LinkSprite has a neat MQ2 shiled. In this tutorial, we just need to add a MQ 2 shield after T board on pcDuino.
Step 1: Wire Diagram
Step 2: Get Arduino-ish Programming API
We need to use github to get Arduino-ish programming API for pcDuino.
If your pcDuino hasn’t yet installed git, you need to install git first using command below:
$sudo apt-get install git
After that, we use the installed git to get Arduino-ish programming API for pcDuino:
ubuntu@ubuntu:~$ git clone http://www.github.com/pcduino/c_enviroment
Step 3: C Code
/* Sample code for MQ2 Smoke Sensor Shield for pcDuino
05/09/2013
#include <core.h>
const int analogInPin =0;
int sensorValue = 0; // value read from the pot
int count1;
void setup() {
pinMode(7, OUTPUT);
void loop() {
count1++;
// read the analog in value:
sensorValue = analogRead(analogInPin);
if(count1==3000)
count1=0;
printf("sensor=%d\n", sensorValue);
The above code can also be downloaded from here.
05/09/2013
#include <core.h>
int count1;
void setup() {
pinMode(7, OUTPUT);
void loop() {
count1++;
if(count1==3000)
count1=0;
Step 4: Compile
modify\test\Makefile:
LIBS=-L../../sample/core -larduino -lspi
INCS=-I../../sample/core/include
TARGET=../../sample/test
OBJS = io_test adc_test pwm_test spi_test adxl345_test MQ2
all: $(OBJS)
@mkdir -p $(TARGET)
@mv $(OBJS) $(TARGET)
io_test: io_test.c
$(CC) $(LIBS) $(INCS) < -o $@
MQ2: MQ2.c
adc_test: adc_test.c
pwm_test: pwm_test.c
spi_test: spi_test.c
adxl345_test: adxl345_test.c
$(CC) < -o $@
clean:
@for i in $(OBJS); do rm -f $(TARGET)/$$i; done
MQ2: MQ2.c in the middle is the new added program.
Reopen the terminal to make library file:
ubuntu@ubuntu:~$ cd c_enviroment
ubuntu@ubuntu:~/c_enviroment $ make
all: $(OBJS)
@mkdir -p $(TARGET)
io_test: io_test.c
MQ2: MQ2.c
$(CC) < -o $@
clean:
Step 5: Run
Now we run the following under test directory:
$sudo ./MQ2
When we light the lighter next to the sensor, we can see the ADC reading goes up immediately.
$sudo ./MQ2
