Introduction: MSAU-2
This is my second MSAU but there are differences, mainly in looks, but there is a new safety in it and trigger guard. Also the barrel is shorter I think. Overall I think the looks are better and it still is most probably just as good as the MSAU.
Pros:
-Strong
-Accurate
-Semi-auto
-Removable magazine
-Doesn't use too many pieces
-Can have optional front grip
-Rather easy to use
-Safety
-Trigger guard
Cons:
-Handle might be uncomfortable for some people
-Can be hard to load at first (But becomes easier with some practice)
More Instructables by me.
Noteconcerning images : Image one shows the MSAU with optional additions. Image two shows the basic version.
Pros:
-Strong
-Accurate
-Semi-auto
-Removable magazine
-Rather easy to use
-Safety
-Trigger guard
Cons:
Step 1: Main Body: Making the Components
Make the following in the quantities given. For reference they have been assigned a letter:
Image 1: Make 1(Part A)
Image 2: Make 1(Part B)
Image 3: Make 3(Part C)
Image 4: Make 3(Part D)
Image 5: Make 2(Part E)
Image 6: Make 1(Part F)
Image 7: Make 1(Part G)
Image 8: Make 1(Part H)
Image 9: Make 2(Part I)
Image 10: Make 1(Part J)
Step 2: Main Body: Construction
Follow the images using the components you've made in the previous step:
Image 1: Attach blue and white rods to part A and a small gear.
Image 2: Add part B and more blue rods, a yellow rod, and a blue spacer.
Image 3: Add parts C, D, E, white and yellow rods, red and orange connectors, and gray spacers.
Image 4: Add parts C, D, F, G, and red and orange connectors.
Image 5: Add parts C, D, E, red and orange connectors, and blue and gray spacers.
Image 6: Cover with part H.
Image 7: Add parts I and J, an orange connector, 2 gray spacers, and a small gear.
Image 8: Add gray connector.
Image 9: Add 2 blue spacers and metallic blue clips.
Image 10: Add 2 gray connectors.
Image 11: Add metallic blue clip.
Step 3: Magazine/Handle: Making the Components
Image 1: Make 2(Part A)
Image 2: Make 2(Part B)
Image 3: Make 1(Part C)
Image 4: Make 1(Part D)
Step 4: Magazine/Handle: Construction
Follow the images:
Image 1: Add white rods to part A.
Image 2: Add parts B.
Image 3: Cover with part A.
Image 4: Loaded.
Image 4: Loaded.
Step 5: Optional
If you want to make the front grip make this. This single image should be enough.
Step 6: Operation
To load remove the mag and place the pin in the appropriate area. Now place the ammo in the mag. Insert the mag into the ammo feed. Next push the white and blue rods in the ammo feed area out to the sides. Hook the rubber bands on the end of the barrel and the trigger spoke. Make sure the rubber bands are on both sides of the ammo. Once all the rubber bands are hooked push the blue and white rods back into the center. Remove the pin. Pull the trigger to fire (in case you didn't figure that out).
Image 1: Magazine with ammo.
Image 2: Rubber band hooked on barrel.
Image 3: Loaded, view of midsection.
Image 4: Safety engaged, magazine out.
Image 5: Safety engaged, magazine in.
Warning- This may cause harm or injury if misused. Do not point it at people. I am not responsible for damage, injury, or death caused by this instructable. Even with safety engaged it can fire. Always treated it as armed.
