Macgyver Hand Crank Flash Light
1,374
12
Introduction: Macgyver Hand Crank Flash Light
your lost in a abonded building the goons that are chasing you are hot on your trail but you cant run cause its to dark
what do you do? well here's what you do
Step 1: Materials
to begin your own macgyver hand crank flash light you will need a few things \
supplies
1. 2 Popsicle sticks
2. a small dc motor
3 an led
4.And a tooth pick
TOOLS
1 lighter
2 hot glue stick or super glue
3 soldering iron or nail
4 electrical tape
Step 2: Motor
you find a small dc motor on the ground through the dim moonlit skys you also come across a small 5v led.
an idea sparks in your head.
quickly thinking you take out your knife strip the leads of the dc motor.
and attach the positive and negative leads to the cathode and anode of the led
Step 3: Hand Crank Handle
you find aPopsicle stick and a rusty nail on the ground.
you take out a glue stick and lighter from your pocket.
melting the glue with your lighter you glue the Popsicle stick to the motor.
after finding a nail on the ground you heat it up with the lighter and poke a small hole in the Popsicle stick.
you stick a tooth pick through the hole you made.
done! at last
Step 4:
the goons have almost there you grab the handle and pray that it works and
BAM
a small but bright light appears in front of you and you escape the goons just in time
i hope you enjoyed my first instructable and i hope to make some other cool stuff in the future
so be sure to follow me and have a good day
First Time Author Contest
MacGyver Challenge
MacGyver Challenge
Be the First to Share
    • Big and Small Contest
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
    2 Comments
    DIY Hacks and How Tos
    Clever. Never having worry about the batteries running out.
    ledmusic
    ledmusic
    Reply 5 years ago
    thanks
