Introduction: Macgyver Timed Door Opener
Step 1: What You Need
the first thing you will need is your trusty Swiss Army Knife.
next you will need
- a good length of para cord
- a weight ( bucket, brick etc... )
- some matches
- your trusty role of duct tape
- apiece of wire
- a little bit of time and your ever so important Macgyver themed music playing in the back ground
Step 2: Find a Weight
Find a brick, or a bucket and tie a long piece of string to it.
Step 3: Find Your Door
Locate the door you want to open
Step 4: Find a Hook
Find a place on the ceiling that you can run a loop of string
Step 5: Tie a Knot
Tie a loop not in the middle of the string that's on the weight
Step 6: Wrap the Knob
Take the end of your first cord and wrap it around the doorknob 5 times and put the brick threw the loop on the ceiling
Step 7: Screw Loose
Find a loose screw in a wall or table, pull the screw out a little and wrap the end of some string around it then use your Swiss Army knife to put the screw back in
Step 8: Tie It Up
Take that string you just wrapped, and tie it very tight to the loop tied to the brick
Step 9: Fuse
Take your wire and bend it in the shape of an Double L. Then bend the end and tie your fuse( string ) to it. Finally tape a few matches to the end of the wire
Step 10: Placing the Fuse
Tape the fuse assembally under the string tied to the loop
Step 11: Set Up
Open the door just enough so that the bolt clears the hole
Step 12: Light the Fuse
Light the bottom of the fuse and wait
