Introduction: Mach3 Zero Probe Tool
This is a Simple Guide on how to use a Probe Tool in Mach 3 to find the exact top of a material.
You can use an input on your CNC Controller, but if you don’t have free inputs because they are used for Limit Switches like in my case. You can just get another CNC Controller when you have an Additional LPT Port, and if not they are very cheap.
I have attached a LED on my Probe, but it has no function other than a visual indication. So the Resistor and LED it not needed. Just a wire and a Metal block will work as well.
What I used is :
A very CNC Controller from eBay for 12$ (5 Axis CNC Breakout Board For Stepper Driver)
You just need a free Input Port on your Controller.
This VB Source code for the Probing Tool.
'VB Code Start
CurrentFeed = GetOemDRO(818)
DoSpinStop()
ZMove = 20.00 'Total lenght of Probe to move before Stop or no Contact Made.
ZOffset = 1.60 ' Plate Hight
ZSal = ZOffset + 2.00 '+ Free Hight, Will possition the Proble 2 MM over the Material.
StopZmove = 0
If GetOemLed (825)=0 Then
DoOEMButton (1010)
Code "G4 P2.5"
Code "G31 Z-"& ZMove & "F25"
While IsMoving()
Sleep(200)
Wend
Probepos = GetVar(2002)
If Probepos = - ZMove Then
responce = MsgBox ("**ERROR** " , 4 , "Probe **ERROR**" )
Code "G0 Z10"
StopZmove = 1
Code "F" &CurrentFeed
End If
If StopZmove = 0 Then
Code "G0 Z" & Probepos
While IsMoving ()
Sleep (200)
Wend
Call SetDro (2, ZOffset)
Code "G4 P1"
Code "G0 Z" & ZSal
Code "(Z zeroed)"
End If
Else
Code "(Check Ground Probe)"
End If
Exit Sub
'VB Code Stop
What I used is :
'VB Code Start
DoSpinStop()
StopZmove = 0
DoOEMButton (1010)
Code "G4 P2.5"
While IsMoving()
Sleep(200)
Wend
Code "G0 Z10"
StopZmove = 1
End If
While IsMoving ()
Sleep (200)
Wend
Code "G4 P1"
Code "G0 Z" & ZSal
Code "(Z zeroed)"
End If
Else
End If
Exit Sub
'VB Code Stop
2 People Made This Project!
- DonS170 made it!
- Md KawserA made it!
21 Comments
7 years ago
Could you please post the compete schematics including the probe. It is probably just a lack of my education. From what I can see you connected +5v from usb to the ground of the inputs... which i thought was connected to -5v. What am i missing?
Reply 1 year ago
it's dangerous that computer! The point of the board is that the motors have a different grounding system than the computer, do not connect the two grounding systems together. PC 5V and PC 5V GNDs are there to drive the other sides.
1 year ago
1 year ago
Thank you! Works good.
Question 3 years ago on Introduction
(Actuary I am not good at English well, So do you understand my English?)
4 years ago
Dear Sir.
I have an error "Error on line: 10 - type mismatch! Please help me! :(((
5 years ago
...yesterdy the script work fine but toady the Z motor don't go down
5 years ago
hvala
5 years ago
When I try to run the script I get check ground probe and nothing else. It worked fine yesterday. Any ideas on what could be going wrong?
5 years ago
thanks for this
6 years ago
Hi kiark ! I get the same issue ! It append often in a middle of job when i
have a tool change. But at the beginning everything work fine !
My solution was to delete (or comment with ' ) line : Code "G0 Z" & ZSal
(from the bottom)
But with this your drill will stay blocked on your probe until you move it up with your keyboard.
So add this line under the one you commented : Code "G0 Z5"
With this line added your drill go up to 5 units !
NB : I'm aware that answer a 1 year old question is strange but this could help anyone else.
6 years ago
Thank you, this is brilliant and so easy to do.
7 years ago
Muchas gracias!!!!
7 years ago
hi.
Thanks for the nice tutorial..pls be kind enough to tell how to connect two breakout boards to mach3 using 2 lpt .. Won't it get confused since the PIN numbers are the same..
I am new to cnc and sport about my bad English
Thanks
Reply 7 years ago
You can enable the second port in the 'Ports&Pins' configuration menu. Then on the Input Signals page you can set for each input pin which port to use (1 or 2 in your case).
7 years ago
good ,working
7 years ago on Introduction
good jobs, thanks for script. so may i know about driver mach 3 ?
Thanks for the script, everything works fine, but when the drill touches the probe the Z-Axis moves down (into the probe) before it moves back up... i fortunately tried it all holding the probe in my hand ;)
Thanks for the script, very helpful.
9 years ago
Dear Sir.
Thank you for this good explanation, but even more, how to connect, Mach3 Zero Probe Tool, in the control box.
