Introduction: Machine Learning With Raspberry Pi
Hi,
This is my first Instructable and moreover my English is not good. So please don't mind if it is not well written.
Background:
Deep learning is a new hot topic in the area of Machine Learning, that shows promising results to achieve artificial intelligence. These days we hear a lot about Machine Learning algorithms from big companies like Google and facebook. But recently a startup called Jetpac brought an iphone app that makes even lay person to use Machine learning. Now the same startup has ported their Deep Learning algorithm called Deep Belief to Raspberry Pi. Although, Pete Warden, the CTO of Jetpac, has given instructions on Github, there are some small changes required to adopt to install it on Raspberry Pi. Therefore, I am writing this instructable.
Step 1: Allocating RAM to GPU
This deep belief software requires, at least 128 MB of RAM. In order to allocate that memory, edit the config file of Pi, by using the following command.
sudo nano /boot/config.txt
Add the following line at the end of the file
gpu_mem=128
Now reboot the Pi.
sudo reboot
In case. if you did not install git before, install it
sudo apt-get install git
Step 2: Install Deep Belief Image Recognition SDK on Raspberry Pi
Now we can install the Deep Belief SDK, by following the below instructions
git clone https://github.com/jetpacapp/DeepBeliefSDK.git
cd DeepBeliefSDK/RaspberryPiLibrary
sudo ./install.sh
Step 3:
Inorder to check whether it is installed correctly or not, follow the below instructions:
cd ../examples/SimpleLinux/
make
sudo ./deepbelief
That should give the following out put
0.016994 wool
0.016418 cardigan
0.010924 kimono
0.010713 miniskirt
0.014307 crayfish
0.015663 brassiere
0.014216 harp
0.017052 sandal
0.024082 holster
0.013580 velvet
0.057286 bonnet
0.018848 stole
0.028298 maillot
0.010915 gown
0.073035 wig
0.012413 hand blower
0.031052 stage
0.027875 umbrella
0.012592 sarong
This is basically telling that the algorithm is analyzing the default image in the library and giving the probability of it being sarong and umbrella. This algorithm is very useful in robotics. I am trying to implement this on my Raspberry Pi Robot soon. You can find more details on my blog.
Credits:
6 Comments
2 years ago
in on raspberry pi3 / debian jessie / updated......
Keep getting error. below is what i get when i use the make command.
pi@raspiFlex:~/Desktop/DeepBeliefSDK/examples/SimpleLinux $ make
gcc -o deepbelief ./main.c -L/usr/lib -ljpcnn
./main.c:11:22: fatal error: libjpcnn.h: No such file or directory
#include
compilation terminated.
Makefile:14: recipe for target 'deepbelief' failed
make: *** [deepbelief] Error 1
pi@raspiFlex:~/Desktop/DeepBeliefSDK/examples/SimpleLinux $ ls
jetpac.ntwk lena.png main.c Makefile
pi@raspiFlex:~/Desktop/DeepBeliefSDK/examples/SimpleLinux $ makefile
bash: makefile: command not found
pi@raspiFlex:~/Desktop/DeepBeliefSDK/examples/SimpleLinux $ sudo make
#include
pi@raspiFlex:~/Desktop/DeepBeliefSDK/examples/SimpleLinux $ (keep getting same error)
Reply 2 years ago
ok so i got ahead of myself and skipped a section is why this error came out.
but now im having this error and i know i did everythign right? it will not open
$ Can't open device file: /var/lib/jpcnn/char_dev <------ the issue as below
pi@raspiFlex:~/Desktop/DeepBeliefSDK $ cd RaspberryPiLibrary
pi@raspiFlex:~/Desktop/DeepBeliefSDK/RaspberryPiLibrary $ ls
install.sh libjpcnn.h libjpcnn.so
pi@raspiFlex:~/Desktop/DeepBeliefSDK/RaspberryPiLibrary $ sudo ./install.sh
libjpcnn installed
pi@raspiFlex:~/Desktop/DeepBeliefSDK/RaspberryPiLibrary $ cd ../examples/SimpleLinux/
pi@raspiFlex:~/Desktop/DeepBeliefSDK/examples/SimpleLinux $ sudo ./deepbelief
deepbelief jetpac.ntwk lena.png main.c Makefile
pi@raspiFlex:~/Desktop/DeepBeliefSDK/examples/SimpleLinux $ ./deepbelief
pi@raspiFlex:~/Desktop/DeepBeliefSDK/examples/SimpleLinux $ leafpad /var/lib/jpcnn/char_dev
anyhelp would be great thanks
3 years ago
Hi, great instructable !
I followed all the instructions but when I entered “sudo ./deepbelief” for the last command it gave me the error,
“Can’t open device file: /var/lib/jpcnn/char_dev”.
Any assistance on how to fix it would be greatly appreciated!
Reply 3 years ago
cd ~/DeepBeliefSDK/source/src/lib/pi/
vi mailbox.cpp
(change #define MAJOR_NUM 100 to #define MAJOR_NUM 249) / save
sudo rm -rf /var/lib/jpcnn/
make clean
make TARGET=pi2
sudo cp libjpcnn.so /usr/lib/
sudo cp src/include/libjpcnn.h /usr/include/
cd ~/DeepBeliefSDK/examples/SimpleLinux/
make
sudo ./deepbelief
3 years ago
Hi, nice set of directions; I'm falling into a different hole; when making the SimpleLinux directory for the "deepbelief" executable, I get the error:
/usr/lib/libjpcnn.so: file not recognized: File format not recognized
Seems to be ELF 64-bit library, not the 32-bit for the other libraries. Any ideas??
Thanks!
3 years ago
I have the same issue as posted below/above. I'm using a fresh copy of Raspbian and a Pi 3. Please advise.
