Introduction: Kids Simple Gripper
I have many students ask me how to build a robot gripper. It's a tough project to do. So i designed this Universal Material Gripper Template {UMGT). It works with any flat material.
Feel free to hack it!
It would be cool to see how many different materials we could use.
Materials - Tools
Depending on what material you choose, the tools will vary as well
  • Paper - scissors
  • Cardboard - scissors or knife
  • Foamboard - knife or hot wire
  • Corrugated board - knife
  • Coraplast - knife
  • Acrylic Plastic - laser cut
  • Wood - scroll or band saw or laser cutter
  • Metal - laser cutter
age 5 -55
Step 1: Download the Template
Step 1 Download the PDF and print it out.
It's an A4 size
Step 2: Attach the Template to Your Material
The easiest way is to to attach is is tape the corners.
Step 3: Mark the Hole Loactions
Use a pointed object to Center Punch the holes.
Step 4: Drill the Holes in All Parts.
Drilling the holes will vary depending on the material you use.
Foam, coroplast, cardboard, corrugated cardboard
These can punched with a sharp object like a wood skewer.
Thicker or harder materials need to to be drilled.
wood and plastic.
Step 5: Cut Out All the Parts
Step 6: Clean and Assemble
Clean
Make sure all the edges and holes are nice.,sand or trim with a knife if necessary
Assembly can be done with a number of fastening techniques.
  • Bolts and Nuts
Drill out the holes nicely, just a little bigger than your bolt diameter.
  • Wood Toothpicks
At every pivot point there need to be a stop Nut of some kind.
  • String and hole punch.
Step 7: Test and Share
Test it slowly, make sure all the joints move smoothly and are not too tight or too loose.
