Introduction: Mad Max Paracord Bracelet
Learn how to make a Mad Max Paracord Bracelet, You will need about 12 feet of Paracord, a lighter and scissors. You will also need a scrap piece of paracord about 8 inches long. This will take about 15 minutes to complete. Learn How to Sell Paracord Bracelets.
Step 1: Mad Max Paracord Bracelet - 1
Fold the piece of Paracord in half to find the center. Then with the center fold, wrap it around your wrist for size, then add about 4 inches. Fold it again, this is where you'll start braiding. Bring the first piece of paracord across, then with the second piece of paracord, go over the top of the first piece, then around the back and in the hole made by the first piece. Then fold the scrap piece of paracond in 2 and put it through the top loops. Like in the picture below.
Step 2: Mad Max Paracord Bracelet - 2
Then with the first piece of paracord, lay it across the front, and with the second piece of paracord, go over the top of the first, around the back, and up through the hole made by the first piece of paracord. Pull it tight.
Step 3: Mad Max Paracord Bracelet - 3
Keep braiding, Take the first piece of paracord, lay it across the front, and with the
Step 4: Mad Max Paracord Bracelet - 4
Keep braiding until the braided part is long enough to go around your wrist. Then cut the loop, pull the scrap piece of paracord out, and run the 2 paracord ends in the 2 holes.
Step 5: Mad Max Paracord Bracelet - 5
Now we will make the ball knot. Make a loop with each piece of paracord, one with the paracord tail in back and one in front, the with the tail from the back, bring it over the top and into the loop it made. Then with the tail in front, bring it around back and up through the loop it made.
Step 6: Mad Max Paracord Bracelet - 6
Then pull the knot tight, make sure it can still fit on your wrist, and cut and melt the ends. You Mad Max Paracord Bracelet is complete. Try more Paracord Projects, get Paracord Bracelet Instructions, or check out the New Paracord Blog.
Sources:
ParacordTime.com
ParacordBands.com
