Introduction: Magic 8 Ball (Magic 2 Ball) With Voice, Round Color LCD Screen and Motion Sensing
In the long tradition of fortune telling Magic 8 Balls I created a self-contained Magic 2 Ball running a Raspberry Pi Zero 2. When you shake the ball and turn it over, the answer tile is displayed on a round screen and the answer is spoken out loud. The 110mm diameter ball is 3D printed in three parts. The round color LCD screen has a 240 x 240 pixels resolution. The sound is high quality PCM and the ball’s orientation is read by a circuit board. The python programs and resources are maintained through a WIFI connection and additional answers can be added.
I had a full spool of dark blue 3D filament, so instead of an eight ball, mine is a Magic 2 Ball to match the color of the two pool ball. This project requires a steady hand and good vision for soldering the connections.
I am grateful to all of the people who have documented their previous Raspberry Pi projects on the web and will try to give credit when appropriate. I could not have made this without you.
Below are the parts I used. Others will work but may require wiring or program changes.
Computer Raspberry PI Zero 2 W
Raspberry Pi Zeros are available from various dealers. I used a Raspberry Pi Zero 2 W and soldered on the header. First I tried an original Pi Zero W, but the response was noticeably slower.
Memory Card SAMSUNG (MB-ME32GA/AM) 32GB 95MB/s (U1) microSDHC EVO Select
Link https://www.amazon.com/dp/B06XWN9Q99?psc=1&ref=ppx_yo2_dt_b_product_details
Any decent memory card with at least 32GB will do.
Audio Amplifier AITRIP 3 PCS MAX98357 Audio Power Amplifier Module I2S Class D
Link https://www.amazon.com/AITRIP-Amplifier-Filterless-Amplifiers-Raspberry/dp/B0912CWB7Z/ref=sr_1_1
This board provides fantastic PCM sound at a decent volume.
Speaker WMYCONGCONG 4 PCS 1.5" 4ohm 3W Audio Speaker
Link https://www.amazon.com/dp/B07DVDW8PV?psc=1&ref=ppx_yo2_dt_b_product_details
Or use any tiny 4 ohm 3W speaker.
Display 1.28" Round LCD Display Module for Arduino/Raspberry Pi/Jetson Nano/STM32 240×240 Resolution 65K RGB Colors GC9A01 Driver SPI Interface
Link https://www.amazon.com/dp/B09FZGYC7L?psc=1&ref=ppx_yo2_dt_b_product_details
Other displays will probably work, including the one in the referenced link in the LCD section. Most are shipped from China.
Accelerometer Adafruit LIS3DH Triple-Axis Accelerometer
Link https://www.adafruit.com/product/2809
This board is for motion sensing.
Jumpers Premium Breadboard Jumper Wires 22AWG
Link https://www.amazon.com/dp/B08QFNH11Z?psc=1&ref=ppx_yo2_dt_b_product_details
Jumpers Haitronic 120pcs 20cm Length Jumper Wire/Dupont Cable Multicolored (10 Color) M to F, M to M, F to F Each
Link https://www.amazon.com/dp/B01LZF1ZSZ?psc=1&ref=ppx_yo2_dt_b_product_details
Any similar jumpers should work. Heavy gauge 22 AWG is easier to strip and solder later.
Optional Parts
These parts are used to create a power extension.
USB Connector 20 Pcs Micro USB Male Type B 5-Pin Jack Port Solder Connector
Link https://www.amazon.com/Micro-Male-5-Pin-Solder-Connector/dp/B07G5ZY7MH/ref=sr_1_1
USB Connector HiLetgo 10pcs Micro USB to DIP Adapter 5pin Female Connector B Type PCB Converter pinboard
Link https://www.amazon.com/gp/product/B07W844N43/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
Obsolete Parts
I originally prototyped a rechargeable battery system. It couldn’t provide enough power. I probably didn’t have enough room in the 110mm diameter ball anyway. If you can add a battery, you will have it all.
Obsolete Charger HiLetgo 3pcs TP4056 Type-c USB 5V 1A 18650 Lithium Battery Charger Module Charging Board with Dual Protection Functions
Link https://www.amazon.com/dp/B07PKND8KG?psc=1&ref=ppx_yo2_dt_b_product_details
Obsolete Voltage Regulator Frienda 10 Pieces MT3608 DC-DC Boost Converter 2A Adjustable Step Up Module Voltage Regulator Board Input Voltage 2V-24V to 5V-28V Output Voltage
Link https://www.amazon.com/dp/B089Y7NDCR?ref=ppx_yo2_dt_b_product_details&th=1
Obsolete Battery IMREN 3.7v Rechargeable Battery 3000mAh
Link https://www.amazon.com/IMREN-Rechargeable-Battery-Flashlight-Headlamp/dp/B09L5M1WN6/ref=sr_1_1
Or any 3.7v battery that has a similar wattage and size.
Step 1: Install Raspbian on Pi Zero
First install the Raspberry Pi Linux operating system on your Pi Zero. I followed the following link for a headless install.
https://www.tomshardware.com/reviews/raspberry-pi-headless-setup-how-to,6028.html
Remove the SD card from your other computer and insert it into your Zero. Turn the Zero on.
Connect to the Zero using your favorite SSH software. I use Putty. If you have trouble finding your Zero you can check your local router to get the wireless IP.
Sign in to your new system with the default user and password.
User pi
Password raspberry
Change your password. If you have or will have more than one Pi, change the host name from "raspberry" to a new value in two files. Then reboot.
passwdsudo nano /etc/hostnamesudo nano /etc/hostssudo reboot
Restart your putty session. Sign in as pi with your new password.
Update your system. This will take a while!
sudo apt updatesudo apt upgrade -ysudo apt autoremove -y
Step 2: GPIO Pins
This is an overview of ALL of the connections. I will expand on this in the later steps. Don’t do anything yet!
1 LCD screen 2 Amplifier
3 Accelerometer 4
5 Accelerometer 6 LCD screen
7 8
9 Amplifier 10
11 12 Amplifier
13 LCD screen 14
15 16
17 Accelerometer 18 LCD screen
19 LCD screen 20
21 22 LCD screen
23 LCD screen 24 LCD screen
25 Accelerometer 26
27 28
29 30
31 Accelerometer 32
33 34
35 Amplifier 36
37 38
39 40 Amplifier
Step 3: Install LCD
I’m indebted to the following website for the information to install the LCD.
You need 8 wires to connect the LCD module. I had a couple of module pins named differently than in the article. Of course you can use any 3V3 pin and any GND pin on the Zero.
ZERO HEADER MY MODULE LABELS ORIGINAL ARTICLE MODULE LABELS
Pin 1 3V3 3V3 VCC
Pin6 GND GND GND
Pin 19 GPIO 10 MOSI SPI SDA DIN
Pin 23 GPIO 11 SCLK SPI SCL CLK
Pin 22 GPIO 25 DC DC
Pin 13 GPIO 27 RST RST
Pin 18 GPIO 24 BLK BL
Pin 24 GPIO 7 CEO SPI CS CS
Enable SPI for the LCD.
sudo raspi-config
Interface Options > SPI > Yes > Enter
Install the required libraries.
wget http://www.airspayce.com/mikem/bcm2835/bcm2835-1.68.tar.gztar zxvf bcm2835-1.68.tar.gzcd bcm2835-1.68/
Configure and compile.
sudo ./configuresudo makesudo make checksudo make install
Install wiring libraries.
wget https://project-downloads.drogon.net/wiringpi-latest.debsudo dpkg -i wiringpi-latest.deb
Install the unzip program, download the demo program and extract.
sudo apt-get install p7zip-full -ysudo wget https://www.waveshare.net/w/upload/a/a8/LCD_Module_RPI_code.7z 7z x LCD_Module_RPI_code.7z -O./LCD_Module_code
Test it.
cd ~/bcm2835-1.68/LCD_Module_code/LCD_Module_RPI_code/RaspberryPi/python/example sudo python3 1inch28_LCD_test.py
If everything worked you will see a clock face on the screen. Copy the lib directory to your new program directory for ease of access.
mkdir ~/magic8 cd ~/bcm2835-1.68/LCD_Module_code/LCD_Module_RPI_code/RaspberryPi/python cp -r lib ~/magic8cd ~/magic8sudo reboot
Step 4: Install Amplifier
For this I’m indebted to the following website.
http://www.lucadentella.it/en/2017/04/26/raspberry-pi-zero-audio-output-via-i2s/
You need 5 wires to connect the MAX98357 amplifier to the Raspberry Pi Zero: Of course you can use any 5V pin and any GND pin on the Zero.
ZERO HEADER MODULE
Pin 2 5V Vin
Pin 9 GND GND
Pin 12 GPIO 18 BCLK
Pin 35 GPIO 19 LRC
Pin 40 GPIO 21 DIN
Change the following file.
sudo nano /boot/config.txt
Comment out one line.
# dtparam=audio=on
Below this add the following two lines.
dtoverlay=hifiberry-dacdtoverlay=i2s-mmap
Add a new file.
sudo nano /etc/asound.conf
Add the following lines to the file.
pcm.hifiberry {type hw card 0} pcm.!default {type plugslave.pcm "dmixer"} pcm.dmixer {type dmixipc_key 1024slave {pcm "hifiberry"channels 2}}Reboot.
Sign back in.
Important A little conversation about the GPIO and hardware drivers. Behind the scene, drivers can reset the GPIO from its original configuration. The driver for the LCD module changes the pins you need for the amplifier. But you can change them back and the LCD module is still happy. You can run these commands at the prompt and I have added them to my program.
Display the current GPIO status, set four GPIOs to their original state and display the new status.
raspi-gpio getraspi-gpio set 18 a0raspi-gpio set 19 a0raspi-gpio set 20 a0raspi-gpio set 21 a0raspi-gpio get
I installed mplayer to play my audio files. You can try other ones.
sudo apt install mplayer
Step 5: Install Accelerometer
The accelerometer can be read to determine the Magic 2 Ball's relative position and if the ball has been shaken.
First turn on 12C.
sudo raspi-config
Interface options > 12C > Yes
You will need 5 wires to connect the accelerometer to the Zero. Of course you can use any 3V3 pin and any GND pin on the Zero.
ZERO HEADER MODULE
Pin 17 3.3V Vin
Pin 6 GND GND
Pin 5 GPIO 3 SCL SCL
Pin 3 GPIO 2 SDA SDA
Pin 31 GPIO 6 INT
Install required Adafruit software.
sudo pip3 install adafruit-circuitpython-lis3dhsudo pip3 install adafruit-circuitpython-busdevice
If you haven’t already, create a new program directory. Create a new file.
mkdir ~/magic8sudo nano 3d.py
Add the following lines.
import timeimport boardimport digitalioimport adafruit_lis3dh i2c = board.I2C()int1 = digitalio.DigitalInOut(board.D6) # Set this to the correct pin for the >lis3dh = adafruit_lis3dh.LIS3DH_I2C(i2c, int1=int1) i = 1print("Move me") while i < 6: x, y, z = lis3dh.acceleration print("#" + str(i), x, y, z) time.sleep(3) i = i + 1 print("Shake me") while True: if lis3dh.shake(shake_threshold=10): print("Shaken!")
Run the test program.
sudo python3 3d.py
Step 6: Power
I created a power connector using a pair of USB connectors as shown in the following link. Do not switch polarity!
https://withrow.io/simpsons-tv-build-guide
(Fun project by the way!)
Now that I don't use a battery, I would probably just run a permanent cable through a hole in the ball to the Zero!
Step 7: Tiles and Waves
Create the folders to hold the tiles and the wave files.
cd ~/magic8mkdir tilesmkdir waves
Use FileZilla or another program to transfer your tile files and wave files to each directory. You can use my tiles and waves or create your own. Tiles must be 240 pixels by 240 pixels. Of course, you can always add additional tiles and matching waves. (Be sure to change the random statement in the program to your new total.)
WAVE036.wav
WAVE037.wav
WAVE038.wav
WAVE039.wav
WAVE040.wav
YESORNO.wav
WAVE001.wav
WAVE002.wav
WAVE003.wav
WAVE004.wav
WAVE005.wav
WAVE006.wav
WAVE007.wav
WAVE008.wav
WAVE009.wav
WAVE010.wav
WAVE011.wav
WAVE012.wav
WAVE013.wav
WAVE014.wav
WAVE015.wav
WAVE016.wav
WAVE017.wav
WAVE018.wav
WAVE019.wav
WAVE020.wav
WAVE021.wav
WAVE022.wav
WAVE023.wav
WAVE024.wav
WAVE025.wav
WAVE026.wav
WAVE027.wav
WAVE028.wav
WAVE029.wav
WAVE030.wav
WAVE031.wav
WAVE032.wav
WAVE033.wav
WAVE034.wav
WAVE035.wav
Step 8: Magic 8 Program
First a note about the program. Yes, it is very simplistic. But sometimes the ability to understand and easily change the program is more important than speed. Feel free to make your own changes!
Copy the "magic8wav.py" python program available below to your magic8 subdirectory.
You can now run and edit the program.
cd ~/magic8sudo python3 magic8wav.pysudo nano magic8wav.py
Step 9: Auto Start
First disable any traces of a previous start and create the following file.
sudo systemctl disable magic8.servicesudo nano /lib/systemd/system/magic8.service
[Unit]Description=Start Magic 2 BallAfter=network.target [Service]WorkingDirectory=/home/pi/magic8ExecStart=/usr/bin/python3 /home/pi/magic8/magic8wav.py > /home/pi/magic8/magic8wav.log 2>&1Restart=always [Install]WantedBy=multi-user.target
Restart the daemon system, enable the service and reboot.
sudo systemctl daemon-reloadsudo systemctl enable magic8.servicesudo reboot
If you are having problems, you can check and erase the logs.
cat /home/pi/magic8/magic8wav.logsudo rm /home/pi/magic8/magic8wav.log
Step 10: 3D Printing the Ball
The ball was designed using the free Tinkercad website. For complex items, I find it handy to create them using multiple steps. Create an item, export all of it as a STL file, import this as a whole into a new project, make changes. Repeat as needed (just like your shampoo). You can even import an item into Tinkercad and convert it to be used as a "hole". This is how I added (subtracted) the speaker slots. But Tinkercad cannot design a smooth ball.
I originally designed the ball to accommodate the battery system. After I eliminated the battery I cut out all of the shelves in the number ball half. Besides I needed all of the available room to cram everything in!
I printed the parts on a $300 3D printer. The printing isn't as precise as a more expensive model but it did the job. Slowly!
Step 11: Assemble the Ball
Important Before assembling the ball I removed all of the jumper pin covers, slid on shrink tube and soldered all of the connections. The ball will be shaken (not stirred) every time!
Insert the ring into one half before crossing between the two halves.
Your hot glue gun is your friend! I used dabs of hot glue to anchor the components inside the ball. Dried glue can be pried up later if you need to make changes.
The 3D printed ring fits snugly at the intersection of the two halves holding them together. I still needed a couple of dabs of glue to keep the halves in place.
Step 12: Mission Accomplished
Congratulations! Hopefully you are ready to have fun with your Magic 2 (8) Ball! Mine has been slightly spooky!
