Introduction: Magic Boat
Materials Required: 1 Origami Paper
Step 1:
Fold the paper in half (along the dotted line) and then unfold it.
Step 2:
Fold the upper and lower halves into halves to form a rectangle and then unfold it.
Step 3:
Rotate 90 Degrees clockwise.
Step 4:
Fold the paper in half and then unfold it.
Step 5:
Fold the upper and lower halves(along the dotted lines) into halves to form a rectangle and then unfold it.
There should be creases that form 16 squares.
Step 6:
Fold the paper diagonally and unfold it.
Step 7:
Fold the paper along the other diagonal.
Step 8:
Unfold it and keep the coloured part topside(Facing you) and rotate so that it is in diamond shape.(♦)
Step 9:
Fold all the corners inside till the tip of the corner reaches the center. You should get a square.
Step 10:
Unfold and Flip the paper upside-down so that the non-coloured part is topside(Facing Up).
Step 11:
Fold the upper and lower halves(along the dotted line) into halves to form a rectangle.
Step 12:
Rotate the paper 90 Degrees Clockwise.
Step 13:
Take the upper two corners (marked with yellow pins) and fold them along the diagonals(marked with dotted lines).
Step 14:
Push down the top part(marked with yellow pin) towards the center of the paper to form a roof-top type shape.
Step 15:
Rotate the paper 180 Degrees Clockwise and repeat step 14.
Step 16:
Step 17:
Take the top 2 points and fold them along the diagonal crease(marked with dotted line) to form a rooftop shape.
Step 18:
Flip the paper upside down so that the rooftop becomes the base.
Step 19:
Fold the top right corner(red pin) along the diagonal crease(dotted line). The red pin should trace over the yellow pin.
