Introduction: Magical 8 Egg
I created the Magical 8 Egg as a playful twist on the classic Magic 8 Ball... something familiar but unexpected. I wanted to take the fun of seeking silly fortunes and package it in a new, lighthearted form that feels even more personal and surprising. It’s a reminder not to take life too seriously! Sometimes you just have to shake things up and see what cracks open :)
It took quite a while to get everything right and almost perfect, but in the end it turned out very nice!
Step 1: Wiring the Speaker to the Adafruit Circut
- Take three wires and cut them down to a reasonable length (not too long and not too short)
- Strip the ends of each wire
- Sauter/Hot glue one end of the wire to the GND hole on the Circuit, and the other end of the wire to the GND hole on the speaker
- Sauter/ Hot glue one end of the wire to the 3.3V hole on the Circuit to the POWER hole on the speaker
- Sauter/ hot glue one end of the wire to the A0 hole on the Circuit to the SIGNAL hole on the speaker
- Turn on the Battery pack and play a tune on your Circuit to make sure the sound comes out from the speaker and not the Adafruit Circuit speakers
- Here is a simple Tune to play if you are struggling!
Step 2: Setting Up the Inside
- Take the Battery pack and tape it to the bottom of the egg (make sure there are batteries in the pack first!)
- Attach the Adafruit Circuit to the battery pack
- Hot glue the circuit to the battery pack right on top
- Take the wires and fold them so they are more contained, and tape them together
- tape the grouped wires to the wall of the egg
~ (After you decorate the egg) ~
- Melt holes with the hot glue gun at the bottom of the egg lid
- Attach the speaker to where you just melted holes with tape
- Close the lid
Step 3: Decorating the Egg
- Take the pearls and hot glue them to the lid of the egg to form an "8" or decorate however you like
- Use the white paint and paint the inside of the lid so the wires can't be seen
(Go back to step 2)
Step 4: The Code (Python)
import time
import random
import math
from adafruit_circuitplayground import cp
SHAKE_ACCEL_THRESHOLD = 15 # Tune this if needed
print("Magic 8-Ball is ready. Shake to get an answer!")
def is_shaken():
x, y, z = cp.acceleration
magnitude = (x**2 + y**2 + z**2) ** 0.5
print(f"Accel magnitude: {magnitude:.2f}")
return magnitude > SHAKE_ACCEL_THRESHOLD
def play_sound(filename):
print(f"Playing sound: {filename}")
cp.play_file(filename)
print("Sound finished.")
# Pulses a color with each answer
def pulse_color(color, duration=3): # 3 seconds
print(f"Pulsing color: {color} for {duration} seconds")
start = time.monotonic()
while time.monotonic() - start < duration:
level = (math.sin(time.monotonic() * 2 * math.pi / 2) + 1) / 2
brightness = int(level * 50)
scaled_color = tuple(int(c * brightness / 255) for c in color)
cp.pixels.fill(scaled_color)
time.sleep(0.05)
cp.pixels.fill((0, 0, 0))
print("Color done.")
while True:
if is_shaken():
print("Shake detected!")
choice = random.choice(["yolk yes", "shell no", "scrambled", "fortune"])
print(f"Random choice: {choice}")
if choice == "yolk yes":
play_sound("yolk yes.wav")
pulse_color((0, 255, 0), duration=5) # Green
elif choice == "shell no":
play_sound("shell no.wav")
pulse_color((255, 0, 0), duration=5) # Red
elif choice == "scrambled":
play_sound("scrambled.wav")
pulse_color((255, 150, 0), duration=5) # Yellow
elif choice == "fortune":
play_sound("fortune.wav")
pulse_color((0, 0, 255), duration=5) # Blue
print("Waiting for next shake...\n")
time.sleep(2) # Prevent immediate retrigger
time.sleep(0.1)
