Introduction: Magnetic Tool Wristband
Building computers can be hard, keeping track of all the small screws and precision screwdrivers. Rather than a cup or a belt, why not keep all your screwdrivers and screws on your wrist?
-Metal from Any Source (used Perforated Cooking Pan)
-Electrical Tape
-Magnets(taken from "Magnetic Tins" from Dollar Tree)
-Metal Snips
-Cutting Tool for Tape
-Metal File
Step 1: Cutting the Sheet
Sheet metal can make for a good bracelet, so cut the sheet long enough to wrap around your wrist and wide enough to attach a magnet of choice.
Step 2: Dealing With Sharp Edges
Because cuts on the wrist are not comfortable in the least, grind down the edges with a file or bend back the edges with pliers, and don't forget to cut the corners to round edges!
Step 3: Bending and Applying Magnets
Apply even force across the plate to form it into the shape of your wrist. Add magnets using adhesive. I took my magnets from dollar store magnetic containers, and I needed to use both from the pack to get the enough force.
Step 4: Finishing Notes
If your magnets are not yet strong enough to hold a screwdriver, wrapping a piece of tape sticky side out can give your wristband extra grip. If you make the wristband out of metal like I did, then you could feasibly ground yourself by connecting the band via alligator clip to a power supply plugged in and switched off. Remember not to switch on the power supply while you are connected to avoid electrocution. Have fun with the Tool Wristband!
