Introduction: Magnetic Stripe Card Spoofer
This instructable assumes that you have basic knowledge of electronics and a cursory understanding of C++.
NOTE: This device is useless unless you already know the contents of a particular magnetic stripe card that you want to emulate. Thus, you can't use this device to do Something You're Not Supposed To Do unless you've already done something naughty to obtain the data from a magnetic stripe card you're not supposed to have.
Don't do naughty things. Your mother wouldn't like it.
Step 1: How It Works
Before going any further, read the document I've attached to this step, "A Day in the Life of a Flux Reversal" by Count Zero. This document is pretty much the bible on how magnetic stripes work, and you need to understand how data is encoded on to them and the basic formatting of the tracks on a given magnetic stripe card. I'm going to go get a cup of coffee; have it read by the time I get back.
Finished? Good.
As you will have learned from your reading, data is encoded on to magnetic stripes by means of magnetic flux reversal in the segments on the stripe. When the card is swiped past the card reader, the changing magnetic field of the passing flux reversals induce a current in the reader element, which is then decoded into binary bits, and the original data stored on the magnetic stripe is reconstructed.
So, in order to emulate a particular magnetic stripe, all we need to do is find a way to recreate the pattern of the way its magnetic field changes as it's being swiped past the reader. How are we going to do this? With an electromagnet!
As you may already know, an electromagnet is basically just a solenoid (coil of wire). When an electric current is passed through the coil, a magnetic field is created. By turning the electromagnet on and off rapidly, we can replicate the changing magnetic field of a magnetic stripe swipe.
The final piece of this puzzle is how to control the electromagnet. Well, we're trying to recreate a particular waveform of current through the solenoid in order to create a particular waveform of magnetism. What's a common way of storing waveforms and converting them to electric current? Sound files! So, all we have to do is encode the highs and lows representing the desired flux reversal pattern into a .wav file and play it back on an iPod or similar music player through the solenoid.
Music players designed to play sound through headphones do not produce enough current to drive the electromagnet in this project, so we will also have to construct a basic amplifier that the signal must be passed through before going to the electromagnet.
Step 2: Wind the Electromagnet
Although a solenoid by itself will produce a magnetic field when electric current is passed through it, a much stronger magnetic field will be produced if the solenoid is wrapped around a core of ferrous material, such iron or steel.
For this project, I cut some small shapes out of 7 mil steel shim material to use as the core. I marked off a tab that is the part of the metal that will actually be inside of the reader slot, and cut some grooves to keep the solenoid in place. When electric current is passes through the coil, the entire steel shim is magnetized.
For the coil itself, just use standard enamel-coated magnet wire. Wrap it until you run out of wire or space. The more turns you have, the stronger your electromagnet will be. Before you start wrapping the wire, cover the part of the steel around which the wire will be wrapped with tape or something to keep the coil from shorting out if a sharp metal edge bites through the magnet wire's thin enamel coating.
After you have wrapped the solenoid, cover it in electrical tape to hold it in place, and solder some wires on to the end of the magnet wire leads.
Make sure not to get tape on the metal face that will be pushed up against the stripe reader's sensing element.
**Thanks to Steve Moskovchenko for helping me to work out the positioning of the coil. **
Step 3: Build the Amplifier
Because a personal media player's headphone jack is not strong enough to drive our electromagnet, we must build a simple amplifier to drive it.
I just threw together this circuit from stuff I had lying around my desk. You can use pretty much any amplifier as long as it has enough gain to drive the electromagnet before it starts to distort. If you really don't want to build this circuit, you could even get some old powered computer speakers and replace one of the speakers with your electromagnet.
Anyway, to build the amplifier I'm using, you need the following items:
6-pin DIP socket
IC1 - LM386 op-amp
C1, C2 - 0.1 uF ceramic capacitors
C3 - 220 uF electrolytic capacitor
R1 - 10 ohm resistor
R2 - 5k trimmer potentiometer (actual value doesn't really matter, just as long as the max is large)
Audio cable with 1/8" phono jack on one end (I just cut the cord off some old headphones)
9V battery clip
Small switch
Prototyping board
Assorted jumper wires
Assemble the circuit as shown in the schematic. Make sure that the ground lead of the phono cable is connected to ground of the circuit. It does not matter if you connect the left or right channel of the phono cable to the input of the amplifier. Also, it does not matter which end of the solenoid is connected to ground, as long as one of them is.
I just soldered some jumper wires for the coil outputs that I connect up later with alligator clips later in order to keep the system modular.
Step 4: Create .wav File of Stripe Data
Finally, you need a a signal to send to the electromagnet. Edit the data array in the attached C++ program (written by geohot) to contain the data from the magnetic stripe that you want to emulate, and compile/run the program. It will output a file called text.wav that is your data file. Upload the file to your favorite music player (make sure it stays in .wav format), and you're in business!
There are two versions of the program in the zip that I've attached - one is for powerPC mac, and the other for PC/x86 mac.
If you are in need of some data to encode, see my other instructable.
Remember, don't be naughty. I'm not responsible for anything stupid/illegal you try do with this device.
Step 5: Hook It Up
Now that you have built all the parts, it's time to play! Connect the music player, amplifier, and coil as shown in the picture. Insert the electromagnet's metal tab into the card reader slot. I recommend testing the device with a card reader/arduino setup as shown in my other instructable.
Step 6: Test It
Make sure the amplifier is on, and play the .wav file containing your data on the music player. If you've done everything right, the electromagnet should transmit the data from the card you're emulating.
If there's a problem with the transmission, try playing with different combinations of gain on the amplifier and volume on the music player. If the signal is too low, the magnetic field produced won't be strong enough, and if there is too much gain, the signal will be distorted.
Some music players cut off the first split second of things that they play. If this happens, your data will obviously not be transmitted properly. You might have to mess with the C++ code or use an audio editing program to add some silence at the beginning of the sound file if this is a problem. I was able to get around this with my iPod by making a playlist that has a .wav of silence before my data file.
Also, mess with the positioning of the metal tab you might have to move it around a little to find the "sweet spot" where its magnetic field is pest perceived by the reader. Additionally, make sure that it is thick enough to trigger the "card present" switch in the card reader.
It took me a few days to get settings that worked, so don't give up if you don't get it perfect on the very first try.
Good luck!
The Instructables Book Contest
115 Comments
8 years ago on Step 4
hi, im professional decoder, i can decode any sound file to track2!
if you need a good decoder contactme
this is im ICQ: 655803449
jabber : decode.wav@jabbim.cz
9 years ago on Step 4
software automatic wav (sound) to ascii (track2) those interested I'll see how it works with live video skype ,, software decode automatic wav to track2 ,,, contact icq 677360044
any body know how is it work ?
10 years ago on Step 3
What should the power output be? I am looking to purchase an amp but I don;t want to get it to small to be useful.
http://www.eachmall.com/goods-28818.html
Specs:
Output Power: 150mW (16Ohm), 16mW (300Ohm)
SNR: >=95dB (A weighted)
Distortion: <0.009%(10mW)
FR: 10Hz-100kHz
Impedance: 16Ohm-300Ohm
Power Supply: Built-in rechargeable Li-ion battery
12 years ago on Step 4
There is an app for the iPhone called square and when you sign up for it they send you a card reader that plugs into your headphone jack ( see squareup.com). The way this app works is by converting the info on the mag-stripe into audio. So could you use an audio file recorded off of the Square card reader rather then using this C++ app to create one?
amigo sou do brasil, se tiver interesse em ganhar dinheiro usando a inteligencia que voces tem ai aqui no brasil me mande e-mail madmaxgyn@hotmail.com
Reply 12 years ago on Step 4
Yup, totally.
Amigo sou do Brasil procuro amigos para trabalharmos na area !!! preçiso de info e faço dinheiro aqui no brasil e despacho o seu cach tenho msr206 preçiso somente de dados please add madmaxgyn@hotmail.com ou envie e-mail
Abraços
11 years ago on Introduction
This type of spoofer will only work single track cards sadly.
So will the direct output from a Square Register cut it?
oh, and if you need a high-tolerance pre-amp for the reading process, Find a cassette player! and unsolder the nearest ic to the mechanical parts and the read head. Good luck!
10 years ago on Step 4
dude you gave me BILLIONS of money! thanks!
hello i was wondering if do anybody know anyting about tracks
12 years ago on Introduction
Good Morning, Is there a way to get the data come straight from a usb port?, instead of having is to come from a audio source, that you could connect the spoofer to a USB port and send the data, and if it is not possible with this king of design, is there a USB SWIPE CARD like Justin longs in DIe Hard 4? when he tries to bypass woodlands server room door.
THank you
Reply 11 years ago on Introduction
The first thing that comes to mind is a cheap USB sound card. All you'd need to do is crack it open and stuff a signal amp in, and depending on the particular card, a headphone jack that connects to the amp's output.
For the amp stage, you could cut size *way* down by using surface mount ICs and draw the power you need straight from the card's power supply (just make sure you keep the current below 500mA or you'll overload the USB port!)
would it be possible to amplify the output of the initial card reader to record directly as audio through a microphone jack (mixer, some form of audio in), and then run that recording of the magnetic pass into the mp3 player and spoofer? It seems to me like a perfectly reasonable analog solution. But I am no expert in magnetic stripes, nor did I read the "A Day in the Life of a Flux Reversal" article (later, I'm just browsing instructables right now.)
another form would be to be able to connect to the mini usb port of an android smart phone and be able to send the signal.
Someone should start a website with known data formats for different card types and make this conversion to audio track on the server side. Seems it would be pretty handy to know the data format and just fill out the form with the required information encoded on the card, since most the information is often pretty apparent and/or in sight. It would generate the audio track and you could play it locally wherever you are.
12 years ago on Step 3
you say that a old powered computer speakers can be used.. what do you mean by this?
