Mahogany LED Bedside Reading Light
Intro: Mahogany LED Bedside Reading Light
Bedside reading lights need to be bright enough for reading, but not too bright to disturb a sleeping spouse. For that, a close, directional light works best, but then you can't have a lamp which will heat up and risk burning you... LEDs are the solution. I found these 3 watts LED bulbs which give out the same light as a 20w (and burning hot) halogen. I designed a fixture which I could mount onto my headboard, push up and down and swivel so it can be pushed out of the way against the wall, using mostly ready-made parts because I do not have a shop and my construction skills are quite limited.
Unfortunately, I did not take pictures as I was making it, so this instructable can't go into great detail... however, combined with my instructable for a tin can lamp, it should be fairly easy to reproduce a similar fixture.
STEP 1: What You'll Need
As you can see in the photos, I made two of these, but the following materials are for a single fixture.
one 18' brass rod with thread on both ends
One 3" brass rod with thread on both ends
Two brass swivels
One metal cup (to use as a frame for the wood)
One Edison base socket with a 1/8" IPS coming out the back
Wire
Electrical tape
One very small toggle switch
Wood tape, preferably 2" wide
Polyurethane, dutch wax, stain, or whatever you want to use to finish the wood
One 3w JDR LED bulb
Whatever I didn't have or couldn't find at the local hardware store I ordered from
www.GrandBrass.com
Google "LED bulbs" and you'll find plenty of suppliers for the bulb.
Two brass swivels
Wire
Electrical tape
One 3w JDR LED bulb
www.GrandBrass.com
STEP 2: Making the Wood Cup
I used a metal cup from a broken ceiling fan light as a base, but I could just as easily have used a regular tin can (see my other instructable).
Since I don't have the tools (or patience) to turn wood, I found some mahogany tape (to match my headboard) and ironed it onto the metal cup. I was a little tricky, but not much more than trying to iron a shirt collar. I didn't even burn my fingers!
I ironed on two layers of wood, and if there was any space at the seams or at the edge between the layers I filled it with a little wood putty. For the top I ironed two pieces face to face, leaving me with a nice thin, but strong and flat piece of wood I could then cut to size with a good pair of cissors and glue on to the top.
Then I stained the wood to match my headboard and finished it with polyurethane.
STEP 3: Preparing the Headboard
A note on my headboard: it actually is not a real headboard. My bed didn't come with one, and as I was trying to figure out how to solve the dirty wall problem my eyes fell upon some spare shelves which were gathering dust in a corner. I figured out that if I hung them up like pictures on the wall behind the bed I wouldn't have to worry about my questionable construction skills.... plus I kind of like the look!
So, to prepare the headboard, I took one of the shelves off the wall, drilled two holes in it from the top (a big one to house the short brass rod, and a little one for the toggle switch).
I then turned it over and carved out some space for the toggle switch using my dremel and some hand tools.
STEP 4: Wire and Assemble
I won't give a detailed description of the wiring here, because how you go about it depends on the parts you'll be using. You can also check out this part of my other instructable or I'm sure you'll find much better instructables on this site.
One thing worth noting is that I cut off part of the thread on the rods because when I screwed them into the swivels some thread was still visible. Trimming the rods gave the fixture a much cleaner look.
STEP 5: Now Go Read Under 3W of Light!
To see other projects I've designed you can check out my website here.
12 Comments
joerice01 12 years ago
How are the fixed to the wall?
belsey 12 years ago
porcupinemamma 12 years ago
rimar2000 12 years ago
evrt 15 years ago
belsey 15 years ago
evrt 15 years ago
belsey 15 years ago
ChrysN 15 years ago
belsey 15 years ago
ChrysN 15 years ago
belsey 15 years ago
