Introduction: Majic Boat Origami Instructions
A simple & easy way to get amazed by a piece of paper
Step 1: Fold Paper in Half.
Do so as perfectly as possible!!. Don't worry I know its hard..
Step 2: Unfold. Now Fold the Paper in Half From the Other Side
You should get to see the "+" sign and paper divided in 4 parts.
Step 3: Unfold. Now Fold the Top and Bottom Crease to the Center.
This should look like a door
Step 4: Unfold . Now Rotate the Paper and Make Another Door From the Remaining Sides
You're paper should now be divided into 16 parts. Like a small chessboard!!
Step 5: Now Unfold the Paper Entirely and Fold It Diagonally
You should a get a triangle after folding the paper like this
Step 6: Unfold and Do for the Other Two Corners
You should get another triangle from this.
Step 7: Now Take Each Corner and Fold It to the Centre
You should get a square after doing this to all the corners
Step 8: Now With the Non-color Side Up,from Top and Bottom Fold to the Middle Line
You should a get a rectangle from this or Door, whatever floats your Boat!!
Step 9: Rotate the Paper 90 Deg So That You Have Short Edges on Top and Bottom
Step 10: From the Top Half Take the Inside Corners and Fold Them Along the Diagonal As Shown. Hold It
Carefully follow the next step.
Step 11: Push the Top Middle Part As Shown to the Center. It Should Look Like the Base of a Boat
It can also be identified as a rooftop.
Step 12: Rotate 180 and Do This Too Other Side Too
You should get a hexagon now
Step 13: Now Rotate the Paper 90 Deg and Take Top Left and Bottom Left and Fold Along the Diagonal Crease
Good going, almost there!!
Step 14: Flip Over, Take Bottom Right As Shown Corner and Flip Along the Diagonal Crease/line
One more step
Step 15: Turn It Upwards and You're Finished
Enjoy your magic boats. Just don't put it in water....
5 years ago
Those are cute, thanks for sharing :)
