Make a Homemade Trumpet/Bugle
Intro: Make a Homemade Trumpet/Bugle
Here's how to make a trumpet out of household items. It sounds just like the real thing, except for the fact that it has no valves.
STEP 1: Materials
Ya need...
O Small length of garden hose
O Medium sized funnel
O Trumpet mouthpiece (found at any music store) OR use the metal connector at the end
O Duck Tape
O Duck Tape
STEP 2: Prepare Hose
Make the hose into a circle (Picture 1). Cut both it's metal head off, and you're ready! Now, tape it as shown in picture 4. If you don't have a mouthpiece, only cut one part off.
STEP 3: Funnel and Mouthpiece
Stick the funnel in one end and if necessary, tape it. Do the same with the mouthpiece.
STEP 4: Playing
Play it just like you would a trumpet or bugle, if you know how. If you don't, here are snippets from http://www.howtodothings.com/hobbies/a3743-how-to-play-the-trumpet.html.
Begin by wetting your lips and press your lips lightly together as if you are about to say "m." Your teeth should be slightly apart. Hold the mouthpiece to the center of your lips, and blow until your lips vibrate. Your lips should be flat and not pursed as in blowing a kiss. Keeping your lips in the same position, move your tongue as if you are about to pronounce the letter "t" (press the tip of your tongue slightly between your teeth without allowing it to stick out of it). Next, slightly withdraw your tongue and simultaneously blow, again creating a vibration. You should just as quickly return your tongue to the "t" position and repeat the steps several times. This movement of the tongue is known as tonguing. Tonguing is important in order to distinctly start and stop between the notes in the music you will be playing. To increase the pitch, you will also need to press your lips more tightly together.
Have fun with your new trumpet/bugle.
Original idea from a book called: "101 Great Science Experiments" can be found at:
http://us.dk.com/nf/Book/BookDisplay/0,,9780756619183,00.html?strSrchSql=101+great+science/101_Great_Science_Experiments_Neil_Ardley
Attached is a demonstration of the three major notes it can play.
46 Comments
kolton.ellis 3 years ago
aizel107 6 years ago
Lilperson101 6 years ago
poobajones 6 years ago
ousmane10 8 years ago
What if you don't have the materials to do it.
BunnyN2 6 years ago
49ersfan18547 6 years ago
I'm going to make one
trevoro9 7 years ago
A TRUMPET HAS 51 INCHES OF TUBING FOR ALL OF YOUR INFORMATION
I had to do some research to find this out. you might find this very helpful
wendycorduroy12 8 years ago
Would this work for me? I have never played a trumpet in my life, but I want to. Would this be a good "beginning" trumpet/bugle for me? I don't want to rent a trumpet, so this is the closest I can get.
BlakeO2 7 years ago
I don't recommend it either, it wouldn't give you the full experience of having an actual trumpet as a actual trumpet has 3 piston valves that extend the length of tubing to get a different sound each time. As poobajones said, you could go on eBay and buy a used one, but if you wanted to be cost effective, but a plastic one, they work the exact same.
poobajones 8 years ago
Unfortunately I would not recommend it. It is very hard to play, even with seven years of trumpet experience. If you are interested in learning trumpet, I would check eBay for a used horn in decent condition, that may be your cheapest bet!
TL11 8 years ago
Rly This is my first yr playing trumpet AND I GOT INTO JAZZ BAND... so really u don't need 7 years of experience. (i dont have some of da materials xD)
Kerimcana 8 years ago
Hi! There is no music store in Izmir, Turkey. Is trumpet working fine if i use Metal Connector?
Or hose connector
Or hose connector
quadracer 11 years ago
Kzummo 11 years ago
sageserver 14 years ago
