Introduction: Make an Old T-Shirt Into Rope
Do you have a lot of old t-shirts/undershirts sitting around? Along with varnishing, cleaning, polishing, etc., those shirts can be turned into rope! One shirt yields about 5 feet of twisted cotton rope, in less than 30 minutes.
Materials
Old shirt
Scitssors
Materials
Old shirt
Scitssors
Step 1: 1.) Cutting
Start at the bottom of the shirt, and cut "around" in a spiral fashion (see picture). The strip can be as wide as you like, depending on how thick you want the rope to be, but in general, 1.5 inches is a safe amount.
Step 2: 2.) Twisting
Now that you have your cloth strip, find the halfway point, and tie a knot a few inches past it. The loop is used to anchor the rope to a post, hook, etc. while twisting. I suggest a strong object, such as this banister, as you will be putting a little tension on the rope while twisting.
TWISTING
Examine any twisted rope. You will see that it is made up of smaller twisted pieces. When the smaller lengths are twisted, they will want to wrap around each other (think yoyo string). If you want to learn more http://en.wikipedia.org/wiki/Rope#Laid_or_twisted_rope
Hold the two lengths of cotton, one in each hand, about 6 inches from the start knot. Twist each length counter clockwise (from your perspective). It should only take a few turns for the pieces to look "round". Now, exchange the pieces you have in your right and left hands. Pass the LEFT hand length OVER there Right hand length. Twist each length a little more, and repeat.
Make sure you stay relatively close to the "twisting point, where the two lengths become intertwined. Otherwise, the rope will not twist "tightly". While twisting, the ends will want to twist themselves. Occasionally run one hand back to undo them.
If you get tired, you can tie onto a chair. Just make sure you keep the tension on the twist.
The rope may be twisted in the opposite direction.
When you get to the end, tie a knot to prevent it from undoing itself.
I hope you enjoyed reading this instructable. If anything is unclear, or you have input on how it could be improved, please comment.
Thanks!
TWISTING
Thanks!
