Introduction: Make Art: THE GOAT
MJ the GOAT
Interactive art project using 3D printing, laser cutting/engraving, and capabilities of the Circuit Playground Bluefruit board and CircuitPython.
When the alligator clip attached to each shoe is touched, a sound bite from that shoe's specific era of Michael Jordan is played from a speaker attached to the CPB, housed within the black pedestal beneath Jordan's head. Going left to right: Air Jordan I, Air Jordan IV, Air Jordan VII, Air Jordan IX, and Air Jordan XI.
Sounds:
Air Jordan I: "This is Jordan, with perhaps the ugliest shoes in the league"
- 1984: MJ wears the Air Jordan I for the first time on the court
Air Jordan IV: "Here's Michael at the foul line. The shot on Ehlo... Good! The Bulls win!"
- 1989: "The Shot" - iconic shot at the buzzer to send Cleveland Cavaliers home in the playoffs
Air Jordan VII: "You step up on that podium representing your country, there's no greater honor than doing that."
- 1992: Member of the 1992 "Dream Team" that captured Olympic gold
Air Jordan IX: "Got it in the air... Michael Jordan's first try on a fly ball... You betcha"
- 1993: shoe released while MJ retired from basketball to pursue professional baseball
Air Jordan XI: Bugs Bunny: "Look out for that first step, doc, it's a real lulu." MJ: "Bugs Bunny?"
- 1996: "Space Jam" Air Jordan 11 worn in Space Jam movie during final showdown of Looney Tunes squad vs. the alien "Monstars"
- Speedy 360 flexx - Trotec Laser
- Original Prusa i3 MK3S+ 3D Printer
- Ultimaker S5/S3 3D Printer
- Alligator clips
- Plywood sheet
- Auxillary port mini speaker
- Circuit Playground Bluefruit
- Mu Editor Application
- CircuitPython
Step 1: Peruse Thingiverse
For this project, I wanted to create something basketball-related. I am also somewhat a sneakerhead, so I naturally gravitated towards Air Jordan shoe templates and instructions. Shoutout to thingiverse.com!!
After finding many shoes to work with, I decided to make them in connection to "His Airness" himself, Michael Jordan. I chose to go with 5 different Air Jordan shoe models.
Looking at "things" on Thingiverse also served as a great brainstorming session for me. I would see something I like, and then think, "Ooh, how can I make this even cooler using what we've learned? How can I connect these things?" From there, my idea took off.
Here are the links:
Air Jordan I: https://www.thingiverse.com/thing:1313776
Air Jordan IV: https://www.thingiverse.com/thing:1313795
Air Jordan VII: https://www.thingiverse.com/thing:1336669
Air Jordan IX: https://www.thingiverse.com/thing:1336692
Air Jordan XI: https://www.thingiverse.com/thing:1392707
Jordan statue head: https://www.thingiverse.com/thing:2034224
Step 2: 3D Print Shoes and Statue Head
After choosing my pieces and downloading their instructions, it was time to print. With the help of the Maker Space TAs, things went very smoothly.
The Jordan shoes required a lot of supports during their print, so I needed to remove a good deal of plastic using pliers after they had finished to reveal their shape (printed on Original Prusa i3). I went with a classic red color in support of the Bulls.
When printing Jordan's head, the TAs recommended using the Ultimaker 3D printer instead of the Prusa i3 because it uses a different type of plastic for its supports, thus taking far less time to remove them--a lovely suggestion. I used a speckled grey color to emulate the color of a real statue head.
Both prints were over 9 hours, so I left them overnight.
Step 3: Laser Cut Basketball Court
As the base of my project, I used the Maker Space Speedy 360 flexx Trotec laser cutter to make my basketball court out of a plywood sheet.
I started off by finding a black and white stock photo of a basketball court that would be compatible with the laser cutting software. Next, within the vector file, I had to make sure that the lines I wanted to cut were in the color red and those I wanted to engrave were in black. I used the red lines to cut out a 20x14in court and the black lines to engrave the court lines.
Step 4: Create Statue Pedestal
Next, I wanted to create a pedestal that would not only support the Jordan head statue, but also house my CPB and speaker to make my project much less cluttered and aesthetically pleasing. I wanted a simple hollow cylinder, but I couldn't find anything on thingiverse.com that matched my specifications, so I designed my own pedestal using tinkercad.com.
I rendered a solid cylinder and then centered a smaller hollow cylinder within the original cylinder to create the shape. I printed it on the Prusa i3 printer and Maker Space TA Gage cut a few mouse holes on the bottom to allow my alligator clips to pass through to my touchpad ports.
Step 5: Create Sound Files and Load on CPB
Next, I searched for Youtube videos that corresponded to the sounds I wanted to create, converted them to MP3 files using a Youtube to MP3 converter, and then used the Audacity application to adjust their volume, length, and converted them to 2200 HZ, 8-bit .wav CPB compatible files. I then created a folder of these sounds and loaded them onto the CPB so that I could call upon them later in my code.
Step 6: Code!
To connect all the pieces together, I used Mu Editor to create a code that would play the specific sounds I created when activated on the CPB board using capacitive touch. The code is attached below!
I also connected my mini speaker to the board using 2 alligator clips attached to the audio out and ground ports, and connected my CPB to a battery pack to make the board mobile. Finally, I attached Chicago Bulls colored red, black, and white alligator clips from my touchpads to the shoes so that when the ends of the clips were touched, the sounds would play.
