Make JCB Bulldozer
Intro: Make JCB Bulldozer
FOLLOW US ON OUR WEBSITE :- http://www.creativitybuzz.org/
First of all it is my 3rd instructables of making remote controlled JCB bulldozer from cardboard.
This is crawler mounted JCB bulldozer.
Please check my 1st and 2nd instructables of making homework writing machine and hover board making machine.
STEP 1: Cut Cardboard Sheet in Shape
Take 3 ply or 5 ply cardboard sheet and cut in the shape of above pictures.
First of all make cab for this bulldozer as per your size.
Then cut the all shape of cardboard sheet as per picture and take all materials.
STEP 2: Stick Cab
Take hot glue gun and paste on cab.Then stick this cab with cardboard sheet.
STEP 3: Stick Support
Stick 3 support for lift cylinder and bucket cylinder using hot glue gun.
STEP 4: Stick Support
Stick 4 support for loader lift arm using hot glue gun.
STEP 5: Make Cylinder
Take two syringe,two nuts,two zip tie.
Pass zip tie through nuts and close zip tie with syringe as per picture.
cut extra tail of zip tie.
STEP 6: Set Cylider in Bulldozer
Take two loader lift arms and set on position of arm.pass the wooden stick through out of two loader lift arm.
Take two cylinders and set on position of cylinder.Pass the wooden stick through out of two cylinder.
STEP 7: Make Bucket
Take coca cola cane and cut them.Stick two cardboard peaces and stick as per 1st pic model.
Take hot glue gun and paste it on both side of bucket.Then stick support on this glue.
STEP 8: Connect Bucket
Take this bucket and link with loader lift arm as per picture.
STEP 9: Make ​hydraulic Cylinders
Take one glass of water and mix with any color for visual effect.
Take one syringe and load full syringe with this colored water.connect syringe mouth with pipe and unload syringe until water come closer two second and of pipe.Take 2nd syringe and connect with this end.
Lets try this is work or not.
Push one syringe handle and you get second syringe handle movement.
STEP 10: Connect Syringe
Use same mechanism of this syringe and create hydraulic mechanism of this syringe.
connect this syringe with bucket arm and loader lift arm.
STEP 11: Make Tire
Take cardboard sheet and cut 5cm round tire as per pic.
Take 5 x 4 cardboard tire and stick 5 tire for make one tire.
Drill hole on middle of this for tire using drill machine.
STEP 12: Make Engine
Take two DC motor and connect with glue gun as per pic.
connect all 4 tire with this dc motor shaft.
STEP 13: Connect Body With Engine
Take Body of bulldozer and stick with engine.
Done !
13 Comments
jencypra 4 years ago
Lovely _Tukii 5 years ago
ElectroRubix 6 years ago
This is just beyond awesomness! so creative!
MelissaM242 6 years ago
Yonatan24 6 years ago
It's what you get when you cut cardboard in half, all the corrugations.
Creativity Buzz 6 years ago
Glumgad 6 years ago
Good work!
Do you use one switch or two?
Abrante3 6 years ago
it amazing
PJ2000 6 years ago
amazing! such creativity.
Kaviga 6 years ago
You could have one motor drive the left track and the other run the right track and add another switch so that they can be run independently. Then you'd be able to steer it using a combination of the two switches. It would be easier to steer with some other type of switches, though. Maybe even use switches that would allow it to go in reverse, too.
