Introduction: Make Music With Your Brainwaves in Real-Time.
Step 1: Install LoopBe30
Get LoopBe30 at: www.nerds.de
a. Ports after reboot - enter 4 (You might have to click the 'Change' button)
b. Click OK
c. Reboot computer
d. Open LoopBe30
e. Disable shortcut detection
f. Click 'Mute None' button
g. Click OK
b. Click OK
c. Reboot computer
d. Open LoopBe30
g. Click OK
Step 2: Open 'MindMIDI Presets.reason' in Reason 6.5+
Open 'MindMIDI Presets.reason' in Reason 6.5+ (located in MindMIDI.zip from www.MindMIDI.com)
a. Under the 'Edit' menu, choose Preferences
b. Click the 'Advanced' tab
c. Set Bus A to '01 Internal MIDI'
Set Bus B to '02 Internal MIDI'
Set Bus C to '03 Internal MIDI'
Set Bus D to '04 InternalMIDI'
d. Setup MIDI Controller (If you do not see your device in the list choose )
e. Click OK
f. Map the sliders/pots to each slider on Reason's Mixer
g. If you do not have a MIDI controller, you can use Reason's Mixer
h. Verify that all volume levels on MIDI controller are turned all the way down (not master volume)
e. Click OK
Step 3: Open 'MindMIDI.bxd' in BioExplorer
Open 'MindMIDI.bxd' in BioExplorer (located in MindMIDI.zip from www.MindMIDI.com)
a. Under the 'Window' menu, choose Signal Diagram
b. Change MIDI 1 - 8 settings (Device needs to be 01. Internal MIDI)
Change MIDI 9 - 16 settings (Device needs to be 02. Internal MIDI)
Change MIDI 17 - 24 settings (Device needs to be 03. Internal MIDI)
(Nothing is routed through the Internal MIDI port 4 - More instruments may be added)
c. If you want to record brainwaves (uses more CPU and Memory):
1. Under the 'Session' menu, choose 'Capture'
2. Press record button
3. Enter filename
4. Click OK
5. Enter name
6. Click OK
7. Press play
d. If you do not want to record brainwaves (uses less CPU and Memory):
2. Press play
3. Enter filename
4. Click OK
5. Enter name
6. Click OK
7. Press play
2. Press play
Step 4: Creating and Recording Music
a. Turn up the volume of at least one instrument per range (One or more instruments from MIDI 1-8, one
or more instruments from MIDI 9-16, and one or more from MIDI 17-24).
b. If you want different musical instruments, change them in Reason, but you will have to tweak the
settings in the corresponding MIDI object in MindMIDI's Signal Diagram.
c. Audio Record Wizard is inexpensive and works well (www.nowsmart.com).
d. You can also save your reason arrangement and replay your recorded brainwaves.
Step 5: Notes and Troubleshooting
Notes:
Check to make sure that you have a steady green on CH1 and CH2. If it is flashing red, check your electrode placements for good direct-skin contact. Do not use in an area with a lot of electrical interference. Double check that LoopBe30's shortcut detection is disabled.
Troubleshooting:
If the music is skipping beats or somehow off beat:
- Check your electrode connections.
- Try a different data transfer rate with your EEG (fixed a problem I had).
- Shut down other programs.
- Restart recording in BioExplorer.
- Check LoopBe30 and make sure that shortcut detection is disabled.
- Restart computer.
- Possibly caused by background computer tasks like virus protection or computer maintenance.
Troubleshooting:
- Restart computer.
