Make New Filament From Old 3D-prints (Recycling)
26,124
44
5
Introduction: Make New Filament From Old 3D-prints (Recycling)
About: 3D Hubs is the world’s largest network of local 3D printing services.
3D printing has been branded as a way to reduce the impact we have on our environment. However, most of the time we’re all too much familiar with a pile of failed prints, that negatively affect the environment surrounding us.
Here at 3D Hubs we want to stop this waste and change the way we produce things. That’s why at 3D Hubs we’ve started the #REMAKE3D campaign to create awareness of the possibilities that are recently popping up to recycle these old prints. So now after you collected your old 3D-prints, let’s look at what to do next.
Step 1: Separate the Old Prints
After you collected your old prints, it is important to separate the different materials. So ABS goes with ABS and PLA with PLA.
If you don’t do this precisely this will result in issues, both extruding and printing, because for instance the melting temperature for both materials is different.
Step 2: Shred the Old Prints
You need something that can tear the prints apart. For instance a Filamaker shredder is perfect or, just a simple office shredder might work. Another possibility is to crush the prints by placing them in a bag/towel and hitting them with a hammer.
Step 3: Setup Your Extrusion Lab
Next, it’s time for the real deal, setting up the extrusion process. There’s a couple of simple tips:
- Make sure you get some kind of filament extruder
- Place the extruder in a stable position
- Make sure the filament can flow out of the nozzle consistently. You can for instance use a winding system or just simply let it fall to the ground. Some setups run the filament through water to cool it. This can work well but requires that the filament is dried afterwards as well. What also works to cool the filament is using a fan.
Step 4: Extrude the Filament
Feed your waste into the extruder and, according to the extruder you own, use its controls to fine-tune the diameter of the filament. For the Filabot, you can, for instance, only control the temperature. Set it higher to increase the flow rate of the filament. This also increases the stretching of the filament however which decreases the diameter. Naturally decreasing the temperature has the opposite effect.
Generally good temperatures for extruding shredded old prints are:
PLA: 140C-170C
ABS: 170C-200C
But this of course depends on many factors so this very well might be different for different situations.
Step 5: Spool It and Use It
If you didn’t spool it already then now is the time to fetch a spool and either manually wind it onto the spool or use a drill to spin the spool until all of your filament is on it.
2 People Made This Project!
  • Game Design: Student Design Challenge
  • For the Home Contest
  • Make It Bridge
    Make It Bridge
5 Comments
annrrr
annrrr
7 years ago
Cool! It would be nice if there were recycling places for this so not everyone had to have the shredder and extruder. Reusing is better than recycling. So the recycling is less good if you are using machines that are not being reused by many people. I dunno if that makes sense
3dhubs
3dhubs
Thanks! We have opened up our first three recycling Hubs in London, Breda and Boston. They will collect the failed prints of their community and turn the waste into brand new filament. ;)
CollinS7
CollinS7
@3dhubs
could you add a "Service" to the hub, so I can mark myself as someone who is able to recycle material? Or where can I sign in?
Thanks and Best Regards
3dhubs
3dhubs
We only have three Recycling Hubs atm, maybe we'll invite more hubs on this program soon. Stay tuned!
annrrr
annrrr
7 years ago
Yay! Good!
