Introduction: Make Operation Boardgame Into Shocking Paris Hilton Operation
This is an easy soldering project that makes operation shock people instead of just make noise or vibrate when you mess up! Fun and less than $10 if you already have the board game.
Step 1: What You Need:
Soldering Iron Stuff (Electrical tape, soldering iron, solder, wire, tester, etc)
Operation board game (I used the Simpsons edition)
FK901. Low Power Electric Shock Kit found @ online stores for about 4$
9V Batt
Printing capabilities for the Paris Hilton overlay
9V Batt
Step 2: The Printed Overlay Application
This is the image file i made and printed out on photopaper. You cut out the black places. You can lay it right over Homer or you can take the Homer off. (Thats what i did) Then I adhered the paper to the top of the boardgame with permanent dbl stick tape.
Step 3: Solder Up the Shock Kit
When puting together the kit don't solder the thumbtacks into the board. Instead run one wire from each of them. One of those wires goes to the bottom of the metal sheet (orange). The other i ran up to where the original wire comes out of the board (green). Drill a small hole for the wire to prodrude.
Step 4: Lastly, Connect the Wire Too the Pincher
In order to not complete the circuit continually i wrapped one side of the pincher with electrical tape. Then I put a size 11 exacto blade over the tape with the wire from the shocker wrapped arounf it at wrapped it with more tape.
Note: I mean no disrespect to Paris Hilton. Notice that she has a "Heart of Gold" in the game!
