Introduction: Make Plastic Sheet From Plastic Paint Bucket
About: Handmade crafts and products that I make using recycled or waste, cheap and easy to available materials. Also custom products are made using a mix of materials.
Hello there,
This instructable will guide you through the process of making any plastic piece into a flat sheet, whether it's a bucket, a mug, a bottle or anything that you need to make flatten.
In this process Heat is applied to achieve the final step. So here we used Press Iron to apply heat, else you can also use a Hot air gun. It will be much convenient.
Also you can check the above video for reference. I have also shown How to make PVC sheet from PVC pipes, you can check that from our YouTube channel.
Step 1: Tools & Materials
  • Plastic Paint bucket (or any plastic material)
  • Press Iron or Hot air gun (for heating purpose)
  • Hacksaw (for cutting)
  • Flat wood piece (for pressing support)
Step 2: Cut the Bucket TOP and BOTTOM
First we need to cut the top and bottom part of our paint bucket, so that only the cylindrical part remains and it's easy to turn it into a sheet.
Step 3: Cut in the MIDDLE
Next. cut the cylinder in the middle, so that it can be flattened and we can apply heat now.
Step 4: Apply HEAT
Now here is the main tricky part. In this step we will use our Press Iron here to apply heat all over the surface. You can also use a Hot air gun if you have.
Now place a paper above the plastic so that is does not get sticky during the process. Then gently press the iron and apply heat to all over the places evenly as possible.
Keep heating about 15 to 20 minutes and make it evenly Hot all the places.
Step 5: Let It COOL
When the sheet will be hot enough then, place a FLAT piece of wood or piece of Tile above it and keep weight on it, so that it remains flattened.
Then let it cool for about 2 to 3 minutes. So, after cooling you will finally get the FLAT piece of you plastic sheet. Repeat this process to any of your plastic item and get a sheet instantly.
__
Hope you've liked the instructable, if so please FOLLOW our YouTube channel for more.
Also, SUBSCRIBE to our YouTube channel "technocraft STUDIO" for more amazing Crafts & DIY Products like this.
__
GET IN TOUCH
Facebook :https://www.facebook.com/technocraftStudioPage/
Instagram : https://www.instagram.com/technocraftstudio/
YouTube :https://www.youtube.com/c/technocraftStudio
Website : https://debojitpaul.in/technocraftstudio/
E-Mail : technocraft43@gmail.com
