Introduction: Make Raspberry Pi Device Become a Bluetooth Object Push Profile (OPP) Client
Introduction
This instructable is based on my experience learning Bluetooth, Object Push Profile (OPP) and Linux. I have lots of mp3 files that I ripped over the years lying in some hard disk. I will show you how to copy the files or any type of files wirelessly using bluetooth technology to your Android phone.
Target Readers
This instructable will mostly benefit Linux users, especially Debian and its derivatives like Raspberry Pi running Raspbian OS.
System Environment
Raspberry Pi with the following specification:
- Model B Debian 7.6
- Bluetooth Radio USB Adaptor
- Mains-Powered USB Hub
Scope
This instructable will show the following:
- Install a OPP client software
- Test that the Raspberry Pi can "push" files to an Android Bluetooth Phone
Step 1: Turn the Raspberry Pi Into a Bluetooth Device
Complete the steps in the "Turn the Raspberry Pi into a Bluetooth Device" instructable if you have not done so.
Step 2: Install OPP Client in Raspberry Pi
Open your favourite terminal emulator, like LXTerminal.
Install the OPP Server:
sudo apt-get update
sudo apt-get install ussp-push
Step 3: Test With an Android Phone
On the Android Phone:
Turn on and unlock your phone.
Turn on the Bluetooth.
On the Raspberry Pi:
Open Terminal Emulator program like LXTerminal:
Discover the Android Phone by running the following command. (You may need to run it several times until you see your Android Phone).:
hcitool -i hci0 scan
Scanning ...
00:1B:FB:19:A0:5B MyRaspberriPi
F8:E0:79:31:7F:C0 MyAndroidPhone
Discover the channel used by the OPP server of the Android Phone.
sdptool browse F8:E0:79:31:7F:C0
(My Android Phone use channel 12 for OBEX Object Push)
Move a picture file (DUN.jpg) from Raspberry Pi to Android Phone:
ussp-push --dev hci0 --debug F8:E0:79:31:7F:C0@12 DUN.jpg DUN.jpg
Android Phone may prompt a message.
Tap OK to start the copying over bluetooth.
Check status message.
If status shows copying is complete, view the picture file in Android Phone.
You have completed this instructable.
