Introduction: Make Streamline Nerf Darts, the Easy Way
Here is a guide for how to easily modify Nerf tagger darts so they fit in Nerf guns like a Recon or Longshot. You will need no tools, only Nerf tagger darts (The kind with Velcro tips) and glue.
These darts fire out of my recon, and still work with other Nerf blasters.
Note: I know there have been other streamline dart instructables made, but this is a different technique.
Step 1: Materials
Here is what you will need:
One (Velcro) tagger dart to each streamline dart you will make
A glue. I use super glue (CA), but most glues will work. I have tried plastic cement, hot glue, etc...
and... that's it!
Now, onto making the darts.
and... that's it!
Step 2: Decapitating the Darts
This is pretty straight forward.
Peel the rubber tips off the darts, trying not to rip the foam. Try going all the way around before removing the tip.
Repeat for all darts.
KEEP THE TIPS!
Note: If the tip starts to peel off without the rubber plug, this is good and will save you a step. Try to keep the plug-part glued in.
KEEP THE TIPS!
Step 3: Removing Rubber Plugs
Again, pretty straight forward.
Look at the pictures for guidance.
You are removing the rubber plugs from the cap of the rubber tip.
Repeat!
Note: Skip this step if your plug is already removed/still in the dart.
Repeat!
Step 4: Gluing Plugs Back In
Now, take out whatever glue you will be using.
Spread a moderate amount of glue on the "bottom" of the plug. Try not to get too much or too little glue on it.
Then, slide the plug back into the dart, on the same end as it was taken out of. Twisting the plug can help spread out the glue.
Wait for the glue to dry.
Note: If the plug is already in, you can reinforce it with a little glue.
Step 5: Have Fun!
Test out the darts in Nerf gun, then go out and blast your err... target.
Here is a video of test firing:
PS: It is in high quality on youtube
Thanks for reading my instructable!
Questions, comments, flames?
