Introduction: Make Wands With Chopsticks
What you need:
Chopsticks
Sanding paper (optional)
Glue gun
Spray paint (or regular paint)
Gold permanent marker (or paint)
Newpaper
Step 1: Buy Chopsticks
This method is very quick so it is ideal for large batches.
If you are making a smaller batch then you can go more intricate in the design
Step 2: Break the Chopsticks Apart
Simple enough.
if you want, you can sand the edges just to smooth away those stray splinters
You can also fine tune the shape here if you like
I did try to shape a pair on the belt sander and the result was pretty good but if you don't have one or need to make a whole lot then I would recommend regular sanding paper
Step 3: Decorate Your Wand
Here you can go as simple or ornate as you want
Do try to make the tip a little more rounded
And go around the entire stick to create a pattern
Anything you add is going to appear later
Step 4: Allow the Glue to Dry
This actually takes really quick. Do make sure that they are upright and not lying down as it will distort the glue
While you are waiting for them to dry, you can lay down some newspaper outside or in a well ventilated area
Step 5: Paint the Wands
I used black and white spray paint because it was what I had
You can use brown spray paint if you wish
Or even regular paint if you like.
However you want to colour them is up to you
I did different things with the paints. Some I painted in just one colour. Others I did one full colour, allowed it to dry and added a fine spray of the other colour over for some texture
Step 6: Allow Them to Dry
At this point you can also check if anything needs a touchup
but honestly the texture and patterns make each one beautifully unique
Step 7: Add Gold Highlights
I had a gold permanent marker which I then just ran over the glued bits with
This helped make the wands really pop and make the patterns more visible.
And as simple as that, you have some wands.
Watch the full video below
