Introduction: Make Washing Machine From Cardboard
Hello! This is our mini washing machine
- A useful, smart DIY washing machine
- It's very easy to make and the material is also very easy to find
- Do you know how it works?
- if not know! See how to do it below
- This product is participating in a contest, please vote for this product. Vote right at the bottom of the post, thank you very much :)
- Let's make it !
Step 1: Water Cans
Prepare 2 cans of water
You can customize your own water cans.
Not necessarily a can of coca-cola like in the video
If possible, try making with Pepsi cans
Step 2: CUT
Prepare sandpaper, rub the can of water and sandpaper to get the bottom
Next, cut off the excess
Step 3: Glasses
Get a thin transparent plastic sheet
Cut it into a circle to make a glass door for washing machine
Then glue it with 502 super glue
After this step, you have the door to open and close the washing machine
Step 4: Make the Front Part
Prepare a cardboard sheet with the size shown in the picture
And draw a circle roughly the size of the door
Step 5: Close / Open
Then create 2 holes on it to attach the door (Third photo)
Use a small steel bar.
And bend it like the picture (second image) and inside there is a water pipe to create the opening and closing mechanism
Once done, attach it to the door section of the washing machine you made earlier
Step 6: Detegent Tray
Make two holes on the cardboard.
Then create the detergent tray.
You can create it very simply.
You can see the illustration above.
You can also add any manufacturer name you like
Step 7: Mechanism of Action
Cut off the excess of Coca-Cola cans (Third photo)
Fully prepared the following: motor, 9v battery and 9v battery connection, a bottle cap, On/Off switch
Make a hole in the bottle cap and attach it to the motor
Next, place it at the bottom of the water cans
Step 8: Electric
Please look at the circuit diagram to follow
After connecting the circuit, put all in to create the body of the washing machine
Put the rear part into the front of the washing machine (fifth image)
Step 9: Prepare Cardboard
Prepare cardboard to complete your mini washing machine.
Step 10: Battery
Make a small hole on the side of the washing machine to install the battery
Step 11: Finished Product. Let's See the Finished Product
I hope you like it.
If you like this safe Lock. Vote to help me. Thank you vary much :))) Thank you very much. Have a nice day ! :))))
