Introduction: Make Your Fidget Spinner Spin Longer
Recently i had bought myself a Fidget Spinner for a cheap rate of 50 rupees.
To my surprise ,when put to test it was very hard to spin the fidget and would not even complete more than 1 rotation.
So i decided to open up my spinner and inspect the ball bearings because that is what was causing trouble spinning the fidget.
So in this instructable i would be telling you how to open up your Fidget and do the cleaning .
So lets do it...
Step 1: Materials Required
You require the following materialsto get your spinner spinning
>Kerosene
>Container
>lubricant
>flat edged screw driver
>compass
Step 2: Open the Fidget Cap
Using a flat edged screw driver remove the caps from both the side of the Fidget Spinner.
Step 3: Open the Metal Casing
My Fidget spinner had a ZZ809 metal casing.
Metal casing which protects the bearings from coming in contact with the external environment and help prevents dust and moisture depositing on the bearing.
Make use of a compass and remove the casing from both side carefully.
Step 4: Clean the Bearings
Now that you have removed the Metal casing .
Put the bearing inside kerosene and stir it for about 2-3 minutes.
Once done you will get a clean and shiny surface on the bearings.
Step 5: Add Lubricant
Add lubricant to the ball bearings which would reduce friction and smoothen spinning
Step 6: Build It Back
Assemble all parts of the spinner again and now you have a Fidget which can spin longer than before.
