Introduction: Make Your Own 4S Lithium Battery Pack
Hey! everyone My name is Steve.
Today I'm going to show you How to Make 4S 2P lithium Battery Pack
Let's Start
Step 1: Gallery
Step 2: Features
Output Power
- 5200 mAh @ 16.8V
Input Power " Charging "
- 2000 mAh Constant Current
- 16.8v Constant Voltage
Built-in Protection
- Over Load Protection
- Short Circuit Protection
- Over Heat Protection
Step 3: Things You Need
Recommended Products
- SUNKKO 787A+ Spot Welder - 1. https://goo.gl/WnYrRG
- NCR18650B 3400mAH Li-ion Battery - https://goo.gl/fTyde8
Where To Buy "Cheapest"
Banggood
1. Connector Holder - https://goo.gl/Cyk76V
2. XT60 Connectors - https://goo.gl/Tm4rRQ
3. SUNKKO 787A+ Spot Welder - https://amzn.to/2yr81bX
4. 18650 Battery Pack Spacer - https://goo.gl/ba67t6
5. Nickel Plated Steel Strip - https://goo.gl/GgpGdq
6. Battery Protection board BMS - https://goo.gl/zcgqBJ
7. Black Silicone Wire Cable - https://goo.gl/bMmPid
8. Red Silicone Wire Cable - https://goo.gl/qMCbD7
9. Kapton Tape - https://goo.gl/KPagVx
10. Mustool® MT223 60W Soldering Iron - https://goo.gl/iH7d5C
Amazon
2. XT60 Connectors - http://amzn.to/2gShZaJ
3. SUNKKO 787A+ Spot Welder - https://amzn.to/2M93P2b
4. 18650 Battery Pack Spacer - https://amzn.to/2M8HSka
5. Nickel Plated Steel Strip - https://amzn.to/2yqNuE3
6. Battery Protection board BMS - https://amzn.to/2trNVsm
7. Black Silicone Wire Cable - https://amzn.to/2MDAsWV
8. Red Silicone Wire Cable - https://amzn.to/2MDAsWV
9. Kapton Tape - https://amzn.to/2K3piJt
10. Mustool® MT223 60W Soldering Iron - https://amzn.to/2K5NBcZ
Aliexpress
Step 4: Assembly
First Step
- Make sure all the batteries are at the same voltage and same capacity
- Now put one by one into the battery holder
- Now use Kapton tape to tape it all
Kapton Tape - it is used to avoid the heat basically it is a heat resistance tape
Step 5: Welding
Second Step
- Now cut down the Nikkle plated strip tape at right length "See the image"
- First, make a pair of 2 parallel battery as shown in the picture
- and then connect all the 4 pair in series
- This connection is called 4S 2P
- You can also see the connection diagram above
4S - Stands for 4 Series
2P - Stands for 2 Parallel
Step 6: Meetup
- Now use a multimeter to measure the battery voltage now I got a reading of 16.49V it may differ from mine reading is totally depends upon the charge of the battery
- Now use Kapton tape to cover the back side of the BMS with several layers
- Now use a double-sided tape to stick the BMS to the Battery
Step 7:
- Now use a soldering iron to pre-tin the solder pad
- Now connect all the pads with small wire as shown in the images
- You can also see the pictures as reference
Step 8: Favoriate T60
- I love to use XT60 everywhere
- Now I used the special holder to hold the XT60
- And used some 14AWG silicone wire and soldered on the XT60
- Now used some heat-shrink tube to secure the connection
Step 9: Final Step
- Now I soldered the XT60 wire to the BMS
- And now used a multimeter to see the battery pack is working
- It's done
You Just Made It Thank you for visiting my Instructables
Stay tuned for next Projects
