Introduction: Make Your Own: Black Hole Fabricator!!
This will tell you how to make a real, down to earth black hole. I swear this is a real instructable! Now, if you have the money, I invite you to build this project. Guaranteed that the FBI doesn't blow your house up first. So, I will also tell you that, because I haven't the money, I have not exactly done this. I CAN tell you that it will work theoretically. Multiple physicists and mathematicians have checked this, and it works. Please read all the directions before creating.
Now, I guarantee that this black hole is DANGEROUS!!!!! So please, make at your own discretion.
Please subscribe!! :)
Now, for the fun part.
Step 1: Buy a 10000 Terahertz Laser
You can find such lasers at price ranges from $10000 to $10000000. Please, I don't guarantee that all 10000 terahertz lasers will be enough, but THAT, is where you come in. Find the correct laser. Please find a good intensity as well. (More intensity, the better.) You can use lenses to increase intensity. I would prefer you to RENT a laser, because it is cheaper. If you want to, you can buy one. Or make one, if you can be sure they won't implode while you do this work.
Also, buy a beam splitter so you can split the laser to go all around the bead in the reaction chamber. That is why it is so powerful. Consistent energy from all sides.
Step 2: Make a Reaction Bead
This is the most complicated part of this whole instructable. You will need:
-tritium
-deuterium
-hydrogen
One isotope each, you will need to place these in a special vacuum sealed, thin layered glass bead.
Make sure it is COMPLETELY airtight!! If it is not, your experiment will go POOF!
Also, if your isotopes are not completely alone, I ditto the sentence above /\ /\ and you will be a sad kitty.
Step 3: Make the Reaction Chamber
The reaction chamber! Well, this is another complicated step, but if correctly done could mean TONS of time saved. You really don't need to make one, but If that nuclear company will not let you have one, I suggest you make one.
Finding a Chamber
You will need an new, sealed nuclear power plant chamber. (Used in the process of nuclear energy conversion.) To get one of these, you must go up to the owner/company and put on your biggest puppy eye face, and ask him/her if he would like to help with the discovery of something "big". If you are lucky, he/she will say yes. Or, as an alternate option, you can buy one. You will need this for the next step.
Making the Chamber
Go buy (Not find!!!) Lots and lots of concrete. And by lots, I mean about enough to cover your house with it in ten feet thick. All chambers are different sizes, and based on your budget and location you may also have to change this. You will also have to line the inside of the chamber with a pure compressed carbon or also known as RCC (Reinforced carbon-carbon) to withstand the beginning temperatures up to 3000 degrees F. You will now have to inlay the chamber with special material I call "diomonia". It is a mix of pure diamond and ceramic. Well, not PURE PURE diamond, but you get the idea. This should withstand short-term temperatures that are very hot. Since diamonds are made in high temperatures, they can withstand and help structural stability for short times. Make sure it has a layer about a few inches thick all around. When you are done, the inside should be a gray-ish white-ish color. Unlike the picture below, which is a nuclear chamber, not a black hole chamber. Unfortunately, You will probably have to replace the inner coatings on each black hole fabrication, but I don't encourage that, because I really don't want everybody making black holes all over the place.
MAKE SURE THE CHAMBER IS VACUUM SEALED!!!!
Step 4: Dropping the Bead Mechanism and Readying the Laser
Place your laser in one spot facing the exact center of the chamber. Now, take a tube and attach it to the ceiling of the chamber. Don't worry about "fireproofing" this or any thing, because this is just to drop the bead in the path of the laser so the bead explodes. Hook up your laser to the correct amount of wattage and a control switch up to the dropping tube, then hook the tube to the computer. (Step 6) This will also be especially difficult because the chamber must remain airtight.
Step 5: Create a Carbon Launcher
Basically you have to make a tube that fires a bunch of carbon at the center of the reaction chamber. Do this by buying a tube, (metal, preferably!) and line it with our special "diamonia" mixture. Attach a small laser in a tank on the back, and hook it up to the reaction chamber. Have a nice switch ready so your computer will be able to fire it at the right time. Fill your carbon launcher with, take a guess, pure carbon, and seal it. The carbon will have to be brimming with photons for the laser to clunk it forward.
Step 6: Hook Up the (Super)Computer
When the laser hits the bead, it will create a temporary star.
Take a very fast computation computer (You could grab one from a server room...or from IMB or someone else like that) and program it so it will fire the carbon launcher just as the star starts to die. The connections between the launcher and the computer should be nice and tidy, so there should be no "frayed or fragmented" pieces. Make sure to double check your programming, or else this will create a large pile of useless hydrogen-carbon bonds, instead of a black hole.
Step 7: Fire the Laser
Carefully fire the laser at the reaction bead. When done properly, it should explode, creating a temporary star. The computer should then fire the carbon launcher, taking all the hydrogen away from the star. This will overload the star, and tear a sizable hole in the matter of space-time, creating your very own black hole.
Step 8: Destroying the Black Hole
You will now have to repeat the WHOLE black hole making process up to step 8. The trickiest part will be hanging the reaction bead, so I recommend you just sorta throw it in, and the laser, still aimed at the center, should hit the bead as it gets sucked in. The star should overload the black hole and destroy it with the star. Remember, time slows down the closer you are to the black hole. The black hole itself shouldn't be very big anyway, so it should be easier to destroy. And because it isn't very large, it will be harder to create a stable singularity therefore you may have to try this several times.
Good luck with your journey, and please, don't destroy the earth!
Thanks for reading, happy building!
346 Comments
2 years ago
It is a comedy plan
It is clear that the editor not understand the mechanism of light and dark matter
So we won't have any black hole in fact
Reply 3 days ago
it has nothing to do with Lightvor dark matter
although I don't believe this instrument wil work
2 years ago
funny
5 years ago
So, theoretically, you can make a time machine because it says you slow down time if you're closer to it. Yeah?
Reply 2 years ago
I think yes, but it will be the people around you who would be time traveling, not you
3 years ago
I just thought, instead of buying all this expensive material, why don't we just get a vaccume tube, fill hydrogen inside it and then light it up in the middle then that will look like a small star because stars are just mass of lit hydrogen correct?
After we can get rid of the firy ball in middle of the tube, won't that cause a gravitational pull?
Say if the sun expires, the sun's gravitational field will collapse into itself true? Just like that if we expire the firy ball, the expired fire ball will collapse and will then turn into a spiral. Why use laser to take out the fire from circle?
Question 3 years ago
I got stuck on the part of destroying the black hole. Please help.
4 years ago
What about spinning object on a spinning object, and them on a spinning object etc.. Make an object spin so fast that way, and make it not break too.. And a bigger mass the object is, is equilevant to larger amount of energy? What if g forces could help creating a black hole in a "different" way? These are just my theories i was thinking about this night.
7 years ago
how does a vacuum stop the black hole from sucking everyting up?
Reply 4 years ago
Because Dyson has the most powerful suction in the world
6 years ago
Can't seem to find ANY of this for sale. Bummer
Reply 4 years ago
craigslist
6 years ago
Can i eat it? I want to loose weight... Or just look thinner
Reply 4 years ago
Idk bro, just try...
6 years ago
The plan is good but what, if any mistake would caused the star not to became a BLACK HOLE but to blast apart as a SUPERNOVA?
Trust me you won't get much time to regret...
Reply 5 years ago
lololololololol
6 years ago
wont a black hole stretch/tear your body apart?
Reply 6 years ago
oh absolutely that's the fun part
Reply 5 years ago
hehe
6 years ago
I Made it!
