Introduction: Make Your Own FM Radio
About: Awesome Electronics Tutorials, Projects and How To´s
In this project I will show you how to transform a TEA5767 and an Arduino Pro Mini into a functional and decent looking FM Radio through the help of a couple complementary parts. Let's get started!
Step 1: Watch the Videos!
The two video parts should give you an overview of what is necessary to build the radio. In the following steps I will present you more detailed information.
Step 2: Order Your Parts!
Here you can find a parts list for the electronics with example sellers for your convenience (affiliate links).
Aliexpress:
1x Arduino Pro Mini: https://s.click.aliexpress.com/e/_d62ALdV
(Optional) FTDI breakout: https://s.click.aliexpress.com/e/_dV4Gqp1
1x TEA5767: https://s.click.aliexpress.com/e/_dUeK6Gf
1x MCP4151: https://s.click.aliexpress.com/e/_dVAqCon
1x TDA1905: https://s.click.aliexpress.com/e/_d655b9d
or (Optional) 1x PAM8403: https://s.click.aliexpress.com/e/_dSgFjif
1x HD44780 16x2 LCD: https://s.click.aliexpress.com/e/_Bf9FG7aX
1x MT3608: https://s.click.aliexpress.com/e/_d8Eky7d
1x TP4056: https://s.click.aliexpress.com/e/_dX8n0hp
1x Micro USB breakout: https://s.click.aliexpress.com/e/_dWadkSj
1x 18650 Li-Ion battery: https://s.click.aliexpress.com/e/_dY2Dqpb
1x Slide Switch: https://s.click.aliexpress.com/e/_dVn7Jlz
1x Rotary Encoder: https://s.click.aliexpress.com/e/_dZs9jUb
1x Speaker: https://s.click.aliexpress.com/e/_dZ3FfXt
6x 10kΩ, 1x 3.3kΩ, 1x 100Ω, 1x 1Ω Resistor: https://s.click.aliexpress.com/e/_dTPpXjt
1x 10kΩ Potentiometer: https://s.click.aliexpress.com/e/_dX83GAF
1x 100nF, 1x 220nF Capacitor: https://s.click.aliexpress.com/e/_dU4FEsB
3x 1µF, 1x 2.2µF, 1x 10µF, 1x 220µF Capacitor: https://s.click.aliexpress.com/e/_d7dOwRz
1x Retractable Antenna: https://s.click.aliexpress.com/e/_dUTSRTD
2x 5mm RGB LED: https://s.click.aliexpress.com/e/_d7mYgib
Ebay:
1x Arduino Pro Mini: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
(Optional) FTDI breakout: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x TEA5767: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x MCP4151: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x TDA1905: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
or (Optional) 1x PAM8403: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x HD44780 16x2 LCD: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x MT3608: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x TP4056: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Micro USB breakout: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 18650 Li-Ion battery: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Slide Switch:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Rotary Encoder: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Speaker:http://rover.ebay.com/rover/1/711-53200-19255-0/1?..
6x 10kΩ, 1x 3.3kΩ, 1x 100Ω, 1x 1Ω Resistor:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 10kΩ Potentiometer: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 100nF, 1x 220nF Capacitor:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
3x 1µF, 1x 2.2µF, 1x 10µF, 1x 220µF Capacitor:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Retractable Antenna: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x 5mm RGB LED:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Perfboard with copper dots: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Amazon.de
1x Arduino Pro Mini: http://amzn.to/1HwhJ8d
(Optional) FTDI breakout: http://amzn.to/1JbxEah
1x TEA5767: http://amzn.to/1U4FTOC
1x MCP4151: http://amzn.to/1TNHlp7
1x TDA1905: -
or (Optional) 1x PAM8403: http://amzn.to/1TNHzwq
1x HD44780 16x2 LCD: http://amzn.to/1TNHCbQ
1x MT3608: http://amzn.to/1U4G2l9
1x TP4056: http://amzn.to/1NnD3hB
1x Micro USB breakout: http://amzn.to/1PNqUYL
1x 18650 Li-Ion battery: http://amzn.to/1U4G3FW
1x Slide Switch: http://amzn.to/1U4G7p1
1x Rotary Encoder: http://amzn.to/1YAoEEp
1x Speaker: http://amzn.to/1U4G5h5
6x 10kΩ, 1x 3.3kΩ, 1x 100Ω, 1x 1Ω Resistor: http://amzn.to/1E9uEhN
1x 10kΩ Potentiometer: http://amzn.to/1YAqrJC
1x 100nF, 1x 220nF Capacitor: -
3x 1µF, 1x 2.2µF, 1x 10µF, 1x 220µF Capacitor: http://amzn.to/1YAqEfK
1x Retractable Antenna: http://amzn.to/1U4GEHF
2x 5mm RGB LED: http://amzn.to/1U4GEYf
Perfboard with copper dots: http://amzn.to/1YAqPI8
Step 3: Create the Circuit!
Use the given schematic to create the circuit. It is always a good idea to wire up the components on a breadboard before moving the circuit over to a perfboard.
Step 4: Upload the Code!
Here you can find the Arduino Code you need to upload before the radio can function properly.
Step 5: Build Your Case!
Here you can find the vector graphics I made for my own case. Feel free to use them to mill your own one or print them out and use them as a template. After your case is complete it is time to mount all your other external components and main perfboard inside it.
Step 6: Success!
You did it. You just built your own FM Radio!
Feel free to check out my YouTube channel for more awesome projects:
https://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
