Make Your Own Needle Threader
Intro: Make Your Own Needle Threader
A small but significant problem had while sewing is threading the needle. Especially as you get up in years, and the eyes are not what they "should" be, when you are tired late at night but have a project that absolutely has to get done, it just gets hard to thread the needle. Here is a simple solution, helps to save the sanity and lessen that frustration!
STEP 1: Gather Materials
Of course there are the commercial threaders, not very expensive, but if you are like me, we misplace them, can't find it when needed, etc. I wanted to be able to continue with out running to a store, so came up with the solution shown here. All I needed was a small piece of "tin" cut from a pepsi can, and a short length of multi-strand copper wire. I used wire cutters, wire stripper, small pliers, etc.
STEP 2: Strip Wire to Provide Several Strands of Individual Wire
I needed a very small gauge wire for this project, and the smallest I had was 30gauge nichrome...it would go through some of the larger needles, but not the smallest. So I came up with the idea of using the strands of wire found in regular electrical cord. This is copper, of course, and is rather fragile in individual strands, but the threading process does not put much stress on the wire at all.
STEP 3: Cut a Shape Out of the Pepsi Can As the Holder
Self explanatory, see pictures. The metal of the can is easily cut to shape with regular scissors. This shaped piece has two parallel lines cut in it to hold the wire in place.
STEP 4: Form Wire by Bending in Half, Then Pulling With the Needle Itself
The pictures show this process. You want the wire when bent in two to be able to go through the eye of the needle. And note that the little tin holder is not used here. So I just keep some strands of wire in my sewing box, and if I need them, they are easy to find.
STEP 5: Place Thread Through "Eye" Formed by Doubled Wire
After you have pushed the wire through the eye of the needle, you have a much larger target to hit with the thread. This can be done in one try, and the thread doesn't have to be wet or cut again, or handled in any way. Much simpler than trying to "hit the eye of the needle!"
20 Comments
umbellate 3 years ago
I worked on this project for two hours. I kept messing up stuff: cutting out too small a piece of the can; cutting parallel lines that were way too big (so they just kept ripping through to the edge); breaking the wire because apparently the thread I was using was too thick (I was using DMC floss, which is very common and is six small threads twisted into one); I had to split the DMC floss into two separate 'strands' because the six-stranded floss was too thick to be pulled through the eye of the needle (which has a fairly large eye); among other mistakes.
I don't want to be overly critical or mean or anything, but following these instructions for this project made me feel wicked stupid.
Rolf 6 years ago
My wife's insulin needles are 32 gauge and fits through a #14 sewing machine needle with no problem. Made a little hook on the end with some jewelers needle nose pliers, works like a charm! Think I will make a "handle" out of epoxy plumbers putty.
lolabell 7 years ago
l find that if l put some glue on both sides of the shop bought needle threaders, where the wire is crimped onto the metal holder, that they last a lot longer, the wire does not pull out but will eventually break but it does extend the life of the threader.
metsakins 8 years ago
Great hack. I've been trying to make a needle threader for a long time, but couldn't find wire thin enough. I'm just going to repair all the threaders I ripped the wire off of! thanks
MarieC30 8 years ago
yes, it took me quite a while to get it to work in a small needle, then i did it by making sure the loop was very fine and pointy and in good lighting. ?
yes i'll let you know if I get this to work, good, because those commercial ones are a bit of a rip off, three for $5.00 and wear out in one sitting.
Creativeman 8 years ago
yes Marie, it y works, but as the comments suggest you don't really need to attach the wires to the piece of "tin". just use as it comes...saves that step!
Bravelute 8 years ago
Well, it's late and my brain will not focus on the stranded wire idea. I know I have a mess of bell wire I'm trying to repurpose, but I'm sure that's still too thick after stripping it. I'd really like to put a "fan" of the wires sticking out of the insulation in an emergency sewing kit I'm making to sell at our church craft fair. If I knew where to get this wire, I think you will have solved the threader problem for the kit. Thanks!!
kenuckles 9 years ago
Great & simple idea ! I simplified further by stopping at step one. I left the insulation on, (about 2 inches) and stripped about an inch of wire. I bend out one strand of wire and put the loop in it. If it breaks, I simply bend out another strand. This way I always have a lot of spares at my fingertips. Thanks for the idea.
Creativeman 9 years ago
Good modification. Thank you.
aminded45 12 years ago
Creativeman 12 years ago
joen 12 years ago
Five stars for you!
rimar2000 12 years ago
sunshiine 12 years ago
jessyratfink 12 years ago
