Introduction: Make Your Own Pepper Spray
Ever wanted to make your own pepper spray?Heres how!
Step 1: Materials Needed
1 Packet Dried chilles
1 Empty snow spray can/or any aerosol can (sprayable snow is the best because its contents are odorless and does not contain water
1 Snapple bottle
1 Glass Jar
1 Strainer
Blender
10ml Syringe
Acetone Paint remover(Nail Polish Acetone contains water)
1 Bike Pump
Butane Lighter refill
Ice
Salt
Large plastic cup
Step 2: Blend the Chillies
Blend the chillies into fine flakes with the blender. Blend enough chillies to fill half of the Snapple bottle
A Gas mask and goggles are optional.The chilli powder will make you sneeze a lot
Step 3: Extract the OC
Fill the Snapple bottle with the dried chillies and fill it to the brim with Acetone.Here i am using a pipette.Leave the bottle to sit for a week.After which,a reddish solution can be seen.Filter out the chillies with a strainer and transfer the red liquid to the glass jar.
Step 4: Fill the Aerosol
Using a 10ml syringe inject the Pepper spray into the snow spray bottle by pressing down.Some of the liquid may leak,so it is advisable to wear gloves. Fill the canister with aaround 70ml of pepper spray. At room temperature the acetone with vapourise inside the can and create pressure.To prevent this submerge the aerosol can in an ice bath.
Step 5: Set Up the Apparatus As Shown Above
I used the rubber tubing of the air pump to transfer butane gas into the aerosol. Butane is used as a propellant. Place the snow spray(blue can) in an ice bath to lower its temperature (Not shown in Photo). The purpose of this is to prevent acetone from creating pressure and spurting out.Make use of the lighter fuel nozzles given to refill the can.
Step A :Depress the nozzle on the aerosol (pepper spray can).To prevent Acetone from vaporizing, submerge can in an ice bath (Optional)
Step B: Depress the nozzle of the lighter refill and wait until the hissing sound has stopped.Once both cans are at equal pessure, release the nozzle of the AEROSOL first before releasing the nozzle of the lighter refill.Not doing this in the correct order will result in pepper spray spurting through the transfer tube.)
Step 6:
Notes:the amount of OC in the solution is undetermined,but it hurts like hell
Capsaicin will degrade in the presence of water ad air.It is best to use aerosol sprays that do not contain water
Try using smaller aerosols like Avene Thermal Spring Water, silly string canisters if you want to carry this around.
