Introduction: Make Your Own Rock Band Ekit Adapter (without Legacy Adapter), Nondestructively!
2023 Update - I was made aware that Roll Limitless now supports Xbox instruments. Since Harmonix doesn't seem like they're going to produce any more RB hardware and tearing them apart is inherently risky, I would recommend you go that route. Hope this guide comes in handy to someone, keep on rocking!
After hearing a popular podcast host mention his concern about his wired USB legacy adapter dying, I went looking for a DIY solution to hooking up a better/custom eKit to RB. Thanks to Mr DONINATOR on Youtube who made a video detailing his similar project that inspired this.
My one concern was having to potentially modify the now relatively hard to find RB4 drum kit, or worse break it entirely as part of the process. This guide is non-destructive and can be completely reversed if you want to sell your plastic instruments for retirement money in a couple decades.
In total this cost me $150-200 to make in hardware. Even with the Alesis Nitro it totaled around $500, around half of the wired legacy accessory adapter on eBay!
Pros
- Non-destructive
- Cheaper than a legacy adapter
- Fully working
- Having the mechanical drum pedal makes playing so much cooler
Cons
- If you follow my initial method using an Arduino for the kick pedal, it needs power and in the interest of time I’m using a separate power cable. I recommend unplugging the Arduino when it’s not in use. This also prevents you from holding down the pedal to sort songs.
- DIY and time
Step 1: Disclaimer
This project is still a work in progress and a lot of firsts for me including Fusion 360 and Arduino!
Make sure you know your kit and measure twice, cut once when working on assembling everything. I’ve confirmed this works with an Alesis Nitro Mesh, if you’ve tried this with a different kit and it works let me know and I’ll add it here! Same goes with settings on the Arduino, I’m still getting back into RB after a long break so can’t attest to it working perfectly on devilishly difficult songs.
Confirmed working
Alesis Mesh Nitro ✅
Roland TD-1K ✅
Step 2: Parts Needed
The exact parts may change as the project develops, check to make sure your drum kit uses 1/4” connectors before buying anything! If you're happy with the stock RB drum pedal you can skip the pedal adapter and just make the case for the cymbals/toms/snare.
Parts
1x Working RB drum kit - The case is designed for Xbox RB4, I can't attest to any other model
Alesis Nitro Mesh
4x - 3.5mm Female jacks
9x - 3.5mm to 1/4” cable
For the pedal adapter
Update - After seeing some feedback and doing some more digging into using a reed switch, that's another option that's just as effective and a lot easier. Here's a great guide that covers that process, skip everything related to the Arduino and just use the reed switch creation. Credit to the creator!
https://www.instructables.com/DIY-Custom-Rock-Band...
Arduino pedal only parts
- 1x Arduino pro mini - Or other Arduino board, I chose this one because it runs at 3v (the same as the drum kit brain), is small, and cheap. You can find off brand ones for very cheap on eBay. Make sure it’s programmed in 3.3v/8mhz
- 1x 1omh resister
- 1x 1W Diode
- Small circut board
- Wire
- USB Micro long enough to reach the Arduino (I'm using a 10ft USB extension cable)
Tools
- Screwdrivers
- Wire cutter/stripper
- Soldering iron
- Heat shrink tubing
- Something to make a case - 3d printed or wooden box!
V1.1 Case - 11-2020
I've updated the case so it has more support and the dpad should work better out of the box. I added a matching 3d printed dpad back to compensate for the height differences between it and the buttons.
This case uses the back of the stock RB drum set where the inputs for cymbals, buttons, batteries, and the kick pedal are located. Be warned that getting the dpad working can be touchy, you may need to adjust how far you’re screwing the board in, but using the custom dpad back it should work close to perfectly.
I recommend printing this in PLA or PETG (my go to) with either the face down, which will result in a rougher texture on the front, or with it vertical standing on the top of the case. Either way with tree supports enabled in Cura, only touching the build plate.
Attached here are a version of the case with holes, without holes (drill your own), the dpad backer, and the Arduino code needed (copy the code within to the Arduino IDE).
Updated Files - 07-2021
I've included step files for both the case and dpad adapter. Please note these were some of the first things I created since touching SolidWorks in high school :-) I will hopefully have another update in the future but have not put more time into this version. If you make improvements please share!
Step 3: Disassemble Your Drums
The entire process won’t take long, in the end you’ll have a mostly assembled drum kit with a missing brain. Take off the legs and lay the main unit face down on the floor.
Unscrew the six screws holding the back panel on, put these aside and keep track of them.
Pull off the back, it may take a little bit of effort but make sure not to pull it too far out. Flip the entire panel over and remove the connectors shown, then unscrew the board itself. Put these screws aside as well.
When taking these connectors out, pull directly up on the connector. I pulled out the socket with a few of them which didn’t cause any damage. If you do just pull them off the wire and press it back onto the board. Make sure you’re orienting it correctly, all of the notched sides face the center of the board
At this point the buttons are going to fall out. You should have (on the Xbox version) the select and start buttons, main Xbox button, A/B/X/Y. You’ll also need to unscrew the bracket holding the dpad in, remove the two screws and pull both pieces apart.
At this point you have everything you need, tuck the cables still attached to the drum somewhere and put it in storage.
Step 4: Prepare Your Wires
3.5mm jacks - Cut the wire so it’s around 10-12” from the end with the jack, then strip 1-2" inches to expose the wires, making sure not to cut too much of the outer copper wire. You can get rid of everything that came with the kit listed in the parts section except for this. Practice stripping the wire on one of the longer scrap pieces!
5x 3.5mm to 1/4” cable - Put these aside, they’re good to go. These will be used for the main snare, toms, and pedal.
3x 3.5mm to 1/4” cable - For the cymbals we need to reverse the polarity of the cable.
Cut them, strip and cross the white/red wires, solder them, then seal everything up. Connect the copper outer wires too (not shown in this picture). I used tight pieces of heat shrink for the individual wires, then another sleeve over everything. You can also use this process to shorten the wires if you would like to.
Step 5: Connect the 3.5mm Jacks to the 2mm Plugs
On the jacks I bought the paired wires from the jack (red and white) are soldered together and hooked up to the up to the red 2mm plug wire, and the outer copper wire is connected to the black 2mm plug wire. Wrap everything with heat shrink tubing to make sure it won’t short.
Do this for all four of the jacks. After making one, I would connect it to the brain and test your drums before you finish the rest.
Step 6: Put the Buttons, Jacks, and Brain Into the Case
Start by putting the dpad and other buttons into the case, keep an eye on them as they will happily jump out as you’re working. Use the 3d printed dpad backer and put the stock one somewhere safe.
Then put the main brain board in and screw it in using the four screws from before, make sure to align the button pads with the buttons. With the current case, push the buttons a few times as you tighten the screws until you reach a point where they all feel right. Put the four 3.5mm jacks into the case, it’s going to require a bit of tucking and squeezing.
Connect the 2mm jack to the four snare/tom ports, identified in the picture below. I labeled each jack and connected them in the iconic red, yellow, blue, green order.
You’ll also want to unplug the wire connected to “E8” (orange), this is the drum pedal jack we’ll route through the Arduino.
Step 7: Arduino Drum Pedal Adapter
Reed switch
I didn’t plan on needing an Arduino so its placing is “wherever it’ll fit”. The good news is it’s a super simple circuit that I pulled from the Arduino knock sensor sample. Please note in the pictures I used randomly colored wires, sorry! I used dupont wires since I'm still tinkering on it, I would solder the wires directly to the Arduino.
This monitors the Alesis kick pedal piezo and when a hit is detected, simulates the stock kick pedal switch being closed for a short period.
- Connect the Arduino's analog in (A0) to the piezo,
- A resister and diode is added to protect the Arduino
- Look at the photo to make sure you're orientating the jack correctly (the program I used for the diagram didn't have anything that represented the JST connector perfectly)
- This goes in the socket that corresponds to the kick pedal
If you’re cramming everything to the case like I did, put a piece of electrical tape on the back of the circuit board.
I’m not going to walk through programming the board but it’s fairly simple and should take you an hour or two if you’re doing it from scratch. Make sure you’re programming it in 3.3v/8mhz, the script settings are made for 8mhz.
This is a great Sparkfun guide on programming the board, it should be the same for any of the generic pro micro boards you’ll find out there.
Hoping in V2 to share the same batteries as the main board or at least get rid of the need for a USB cable. I printed this case and used the bottom half to tuck the boards in.
Step 8: Tuck Everything In
Route the Arduino’s power connector in through the side hole. Tuck everything in, being careful not to pinch, crush, or unplug anything. I found that the Arduino case I used nestles nicely in the spot shown in the picture. Use four of the screws you put aside earlier to fasten the back on, in the V1 case that’s the top and bottom two sets of holes.
Step 9: Other Recommended 3d Printed Parts
Feet for set - I mounted mine to a 2’x4’ piece of particle board
Cymbal screws - My goal is to print one for each of the three colors
Step 10: Set It All Up
The case is designed to fit right into a normal Alesis drum brain mounting bracket. Connect all the drums, cymbals, and kick pedal, then plug in the USB power for the Arduino. You are ready to rock!
If you find that the drum pedal isn’t as responsive or is double registering, try modifying the hit threshold and wait period in increments of 25.
Thanks for reading this far, if you've followed this guide let me know any improvements you make to the process!
15 Comments
Question 1 year ago on Step 4
hello, Im a novice so help me out... am I splicing the alessis tom and cymbal wires into one jack per corresponding color by RB convention? That step seems intuitive but isn't clearly spelled out...just asking because I'm dumb
Question 2 years ago on Step 2
Hi! Thanks a lot for this tutorial!
i did it with a RB 2 drum set from xbox 360 so i have a problem with the kick pedal, this drum works with 3 batteries so i dont know how to program the arduino, Can you help me with this?
Answer 2 years ago
I can get to work on the arduino fix if he doesn't get back to you. To be honest, I skipped that part and made my own rock band pedal with a $40 drum pedal, a neodymium magnet and a reed switch. so much better, you can probably make it yourself.
Reply 2 years ago
Yeah sorry AuxiliaryALEX I'm not sure if the Arduino would work nicely with a 3 battery setup, don't want you to fry your set! You can always use the standard RB pedal or use farmercurt88's suggestion for a reed switch version
Reply 2 years ago
I see..
Thank you so much for take your time to do this post. I'm still trying to make work the rb2 drum with arduino lol
Reply 2 years ago
Thank you so much!
Can you provide more detail on getting good results on the 3d print (what printer you used, what filament, mm, sanding, etc.)? I am completely new to 3d printing and I'm having trouble getting the board to sit properly and buttons to move smoothly in an out of the holes.
Also, the Dpad seems to be the most unreliable piece even on the original drums and I was considering trying to alter your design in Fusion 360 to include a more traditional Dpad (cross shape), and do away with the round piece altogether. I may be using the wrong terms, but can you post the "solid" file for Fusion 360 so it's easier to alter? As it is, it seems like I have to convert the .stl to a solid in order to make those types of changes.
Answer 2 years ago
No problem, I'm printing mine on a Tronxy XY-2 PRO 2, .4mm nozzle, PLA, no post processing after printing besides removing supports. One thing I'd note is that I found printing the case flat size down with tree supports enabled in Cura, touching build plate only, will get you the cleanest print. That will result in a bumpy surface finish but all the button holes and supports print nice and clean.
Here's a f3d export of the adapter, I think that will preserve the history. Hope that helps and if you don't mind post any update design you make!
https://www.dropbox.com/s/6tdao2cwcbvw828/Dpad%20adapter%20v10.f3d?dl=0
Reply 2 years ago
Thanks. Can you also provide a f3d file of the case itself?
Reply 2 years ago
Sorry for going MIA, I've updated the post to include step files for both 3d printed parts
Question 2 years ago on Step 7
Can you give any more detail on what to expect with the Arduino? I uploaded the program you posted here and I believe I wired it all correctly, but I am getting no response whatsoever from the kick Pedal on an Alesis Nitro. Should any lights be visible on the Arduino when detecting values on A0?
Answer 2 years ago
To diagnose, I would start by making sure the Arduino is reading values from the kick pedal piezo. In the code if you change "const int printtoserial = 0;" to " = 1;", it will print some information out to the Arduino serial monitor. Once you get that reporting some values, if it still doesn't work it's something with your wiring between the Arduino and the board. After finding the reed switch method to using the drum pedal, I'm going to try this myself and update the guide. Seems much easier and less fiddly than using an Arduino! For now I've updated the guide to mention this instructable: https://www.instructables.com/DIY-Custom-Rock-Band-Pedal-just-like-the-Destroye/
2 years ago
Absolutely wonderful post. I stumbled upon this fantastic instructsble while looking up workarounds for the legacy adapter. To start I have a Roland td-1k (that works with this process) but ended up getting an Alesis nitro mesh on fb for $150!! The mesh pads are great. I made 2 changes though,
1. I bought female 1/4 jacks and soldered them to the jst plugs.
2. I didn’t use the Adriano and instead took apart my existing kits pedal for the reed swirch and magnet.
All in all this works perfect and was so simple. Thanks again brandonjcooper.
Reply 2 years ago
Glad to hear it helped! With a few people recommending the reed switch, I'll have to try it myself.
3 years ago
Thanks for sharing :)
