Introduction: Make Your Own Silicone Molds
Using simple supplies, you can make your own silicone molding putty.
Step 1: Watch the Short Video Tutorial Here!
Step 2: You'll Need
Cornstarch
100% Silicone
Baby oil
Americana Acrylic Paints
Mixing bowl
Objects to cast
2-part plastic or air dry clay
Step 3: Make the Putty
Squeeze out enough silicone to cover your object
Add in about 1/2 the amount of cornstarch
Add a small dab of Americana Acrylic Paint
Add in several drops of baby oil
Mix thoroughly with a small spoon or stick
*Cover your hands in cornstarch and knead
Step 4: Make a Mold
Roll the putty into a ball
Press in your item making sure it covers all the details
Let cure for about 20 minutes
Remove the object
Fill with 2 part plastics, Sculpey or air dry clay
95 Comments
2 years ago on Introduction
Love this idea! Can these be used for resin as well?
Question 3 years ago
Hi, I'm trying to make a Replica of a peace of glass using GE 100% SILICONE all purpose Silicone to make a mold. But no luck yet
4 years ago
Do you know if the finished mold can go in the oven?
5 years ago
I want to make soap can I use this
Reply 5 years ago
Yup!
6 years ago
I want to make silicone molds to make fondant forms for decorating cakes. Do you have a recipes for food products?
Reply 6 years ago
For food products you really need platinum silicone putty - its the only one that's food and skin safe.
Other silicones release strong acetic acid, or use tin - and these are no good.
This sort of thing:
https://m.youtube.com/watch?v=oxeRKWDWT0c
If it's for something that's a one-off, you could use something called alginate. It's very cheap, but only good for one go really - used to make body casts and dental casts. Check its not minty before buying.
Reply 6 years ago
I don't.
6 years ago
Good Morning, Mark!
I am currently attempting to make a synthetic skin for an animatronic stingray. The cast needs to be flexible to allow for wing movement.
I was thinking about using silicone molding and urethane/latex casting. I know that in your video you state that plastics are best to use with the silicone mold. Do you think that I would be able to produce a functional, flexible cast using the silicone mold?
Reply 6 years ago
It sounds like you can. The good thing is that it's not very expensive to make these molds so you're not out a ton of money either way. Good luck and let me know how it goes.
7 years ago on Introduction
Super cool! Does the acrylic paint serve any specific purpose or is it just to add some color? Love this instruct able! :-)
I like it because I can easily see the details in the mold when I pour. When it's white sometimes you can't see the bubbles.
I maintain that the acrylic paint has a chemical purpose. Silicone needs moisture to cure, which, ordinarily, must diffuse in from the outside. So, ordinarily, silicone caulk is useless for molding, as the sections are too thick to cure the interior. The acrylic paint contains water, which you are mixing throughout to enable cure.
Reply 6 years ago
You are correct about the paint serving a purpose... You can swap out the paint for Glycerin. You can find Glycerin at Walmart or any pharmacy. Its a clear plastic squeeze bottle.... Just a couple drops of it will cure silicone without a doubt. Just dont add to much as it will cure faster the more you add... a couple drops to 1/4 cup of silicone is what i use. Also if you want the color still you can just add a couple drops of food coloring along with your Glycerin.
Reply 7 years ago
Hi, just wondering if the mould ends up
rigid or flexible
Definitely flexible.
flexible!
I've had some for a couple of months and they're still flexible.
6 years ago
Can I use olive oil instead of baby oil
6 years ago
would this type of mould be okay to use for making plaster casts?
