Introduction: Make a 1-Leg Footstool
In a recent YouTube collaboration, myself and Dorian Bracht met a challenge to build footstools to a set specification. We came up with very different designs. Here's how I made my single leg footstool.
WARNING
Once you have one of these, you'll be tempted to put those feet up and live the lazy life
Entered into the Lazy Life challenge, so please vote if you like it :)
Step 1: Preparation
Grab a load of hand tools - I made my footstool without any power tools, but you can easily substitute power tools if you prefer.
Download the plans (these are also on my website, womadeod.co.uk , where you can donate by PayPal, or become a Patron, if you would like to support future projects)
Step 2: The Top
The top is a quarter circle, which I marked out using a try-square, steel rules, string and pencil. Tenons are marked out on the two radiuses
My top was made up of two boards, which were edge jointed and glued
The curve was sawn with my bow-saw, and cleaned up with a spokeshave
Step 3: Arms, Leg, and Feet
The arms, leg, and feet, are prepared to size, before the joints are cut
The joints should be clear from the plan, but additional images, and a video are included in the appendix (final step)
They should be fitted carefully, so that they are a close sliding fit
Step 4: Top to Arms
Cut the long tenons on the edges of the top, and chop the matching mortises in the arms
The top should end up flush with the upper surface of the arms
Step 5: Fare Parts and Glue Up
Dry fit the footstool, and mark the transitions between the different components. Then disassemble and fare the parts so that all the transitions flow together nicely
Apply glue to all joints and assemble as one. Clamp as necessary to close all the joints up, and leave for glue to cure
Step 6: Finishing
I finished the footstool with several coats of tung oil. This is best applied liberally, and then rubbed dry before it gets sticky (ten minutes or so), and repeated after a few days, until the lustre you desire is achieved.
That's it! Now sit back and put your feet up ;-)
Hope you enjoyed my instructable. Check the next step for an appendix with helpful information on the main joint used in the footstool.
Step 7: Appendix a - Additional Pictures of the Main Joint
To make a little more sense of the main joint, I made another video, and produced these 3D images. I hope they are helpful. The pin shown in the images is particularly useful if you don't have any glue!
