Introduction: Make a Chalk Bag
Anyone who climbs regularly needs a chalk bag. As an added bonus, I integrated pockets into this one. Next time you're out climbing and need a place to stash your cash and keys, here's your answer.
This instructable will be following how I made version 1.0 of this bag from an old pair of jeans. It worked out OK, but the pockets aren't that useable. The cargo one pictured third is definitely an improvement on my first attempt. However both follow the same construction techniques, so this should guide you for whatever kind of chalk bag you would like to make, including a standard one without pockets.
Step 1: What You Need
You will need:
Outer fabric for your chalk bag. I used an old pair of jeans for this one so I could integrate the pockets and belt loops into the design. The second one I made (see third intro image) was from an old pair of cargo pants, and I used the cargo pockets as part of the design. If you are doing a plain chalk bag, you can use whatever fabric you like, provided it is relatively sturdy.
Lining fabric: fleece or something soft works best, because it will have a stickiness factor for the chalk.
Cord/elastic: to loosen and tighten the bag
Cord stop and large eyelet for the cord/elastic
Step 2: Cut Fabric for Outer Cylinder
I wanted to integrate the waistband of these jeans for my first chalk bag, so I used that as the top of my "pattern". I cut a rectangle of roughly 7" x 13" from the pants, measuring the 7" length down from the waistband, and the 13" wrapping around from front to back of the pants. This caused the rectangle to be relatively uneven because of the shaping in the side seam of the pants, which is why I show in the 3rd and 4th pictures how I made a small dart to make the piece more uniform. For a standard chalk bag, just cut a rectangle about this size from your fabric.
If you want to use more than one panel for your outer fabric that is also an option, as long as the total pieced together size is roughly 7" x 13". This is where you can get creative, so have fun!
Step 3: Cut Fabric for Inner Cylinder
The size of your lining fabric will depend on how you will be finishing the top of your chalk bag. In the denim one I am making here, there is no binding on the top, so I cut my lining fabric to be 1/2" taller than my outer fabric (7.5" x 13") to allow for me to fold it under and create a clean edge. However if you are going to bind the top with a separate piece of fabric (like in the cargo one in the main image of this instructable), you can make your lining fabric equal in size.
Note that in this image I have the outer fabric and inner fabric folded in half on the fold - it doesn't matter whether you cut it out this way or not, but I realize this image could be slightly confusing at first glance. You want one big piece, not two small ones!
Step 4: Sew Outer Cylinder
Fold outer cylinder in half, right sides together. Sew along side seam. Turn right side out.
Step 5: Cut Fabric for Bottom Pieces
Using your newly formed outer cylinder, trace around it to get a rough size for your bottom pieces. You want your circular bottoms to be slightly bigger (1/4" or so) than the circumference of your outer cylinder. Once I had a general size traced, I found a jar top that matched in size, and traced that to clean up the circle.
Once done tracing, cut one circle pattern piece from both your inner and outer fabric.
Step 6: Sew Pieces Together
You already have your side seam sewn on the outer cylinder. Turn it back inside out, and pin circular bottom piece you just cut to the bottom of your cylinder, also wrong side out. Sew it together, removing pins as you go.
Do the same procedure for your lining fabric. Fold the rectangle in half, wrong side out (if there is a face to it). Sew the side seam. Then pin and sew the bottom circle.
In the next step you will be working with your lining inside out, which is why it is shown that way here.
Step 7: Add the Eyelet
Cut a small hole in your outer shell, and hammer in a large eyelet. It should be roughly 1.5" down from the top of the bag. It will only be through the outer shell.
Step 8: Add the Cord
Now for the tricky part - the cord. For a chalk bag to work properly, it needs to cinch smoothy from all sides in the lining only, which keeps your chalk safely inside when you aren't actively using it, and allows for easy access when you need some. The mechanism behind this is a double loop of the cord, which makes it cinch evenly instead of off to one side.
To keep the cord in place, you will sew a loop for it to go through on the lining, which will be on the opposite side as your eyelet. The loop should be sewn on the same distance down from the top of the bag as the eyelet, about 1.5".
Wrap the cord around the liner bag, and through the loop twice. Place the lining bag inside the outer shell, with the loop for the cord on the opposite side as the eyelet. Thread the two loose cord ends through the eyelet. See the images and diagram.
Step 9: Finish Top Edge
Almost done! The last bit of sewing is to finish the top edge. In this particular bag, my outer shell already has a finished edge as it is the waistband of pants, so I made my lining fabric a bit taller to allow me to fold it under for a clean finish.
Pin the lining under, and sew around the top of the bag.
If you choose to bind the top of your bag like the cargo one in the third main image of this instructable, take a 1.5" strip of fabric, lay it down along the outside of the bag and lining aligned to the top and, sew 1/4" from the edge. Then fold around to inside and tuck under, and sew again for a clean bound finish. Also, many commercial bags use nylon ribbon folded in half as a binding, this is an option as well.
In both bags I made, I had a belt loop integrated into the design to clip it to my harness. If you are making yours from yardage instead, you will need to add a loop on the opposite side as the cord so you can clip the bag to your harness.
Step 10: Add Cord Stop, and Finished!
Thread the two loose cord ends through the cordstop, and tie the ends of the cord so it will not un-thread.
And you're finished! Climb on!
EXTREME! Challenge
28 People Made This Project!
- Suzygirl46 made it!
- Dylan2883 made it!
- pmiller18 made it!
- oktomus made it!
- Lanbox made it!
- ScubaSeif made it!
- DenisT30 made it!
- SilverSkye made it!
- yaroshka made it!
See 19 More
24 Comments
8 years ago on Introduction
Think I might try making a bouldering bucket version of this! Will be my first ever sewing/fabric project.
Reply 2 years ago
That's a great idea! How did you get on? I am looking to do the same
6 years ago
Fantastic Instructable! Just finished one from a pair of my late Husband's cargo shorts, now he will be with me whenever I climb:) Thank-you!!
Reply 6 years ago
You're welcome! Glad that he can be with you in this way. <3 to you!
6 years ago
wow so cool,this is my first time seeing this ible!! i made one similar before!!
9 years ago on Introduction
do u think guys would get made fun of if they carried this around and this would make a goood survival bag
Reply 6 years ago
Nah. really anymore, society is pretty accepting.
7 years ago on Introduction
i'm gonna try this we need some presents for the kids climbing club i teach but there's like no budget so i need to get creative need to make 12 for the kids and if they turn out good i think 4 more for the trainers
Wow!! A good idea, I was wondering what to do with upper jeans scraps!
This is very cute and functional! Thanks so much for sharing your hard work and do have a splendorous day!
sunshiine
how do u open it
Once you follow the directions for inserting the cord, the way it closes is very easy and exactly how the store bought ones close.
Thank you so much for the great instructions! I was looking for a different pattern for a chalk pot for my bouldering daughter and this was exactly what I was looking for!
I went to the thrift store and bought a pair of child's Levis and cut the pattern trying to incorporate all the logos. Shes going to love it!
Finished mine the other day and it came out great - thanks for the instructable! :D
9 years ago on Step 10
This is a very clever setup and good use of old jeans! Was looking for an option for my weight lifting chalk and this would fit the bill.
great jeans style chalkbag -- also created a pattern but on craftsy - however I should try out this site, seems to be much cooler - anyways. here is the link to the free pattern .. http://wurzelkraut.com/en/2012/08/19/chalkbag-bauanleitung/ -- marco
id add a zipper on the top so it would be easy to open
10 years ago on Introduction
This is great! Mine looks amazing. I put a little robot on it.
cool.
Try using teddy animals insted. Then you can make som intresting/funny calk baggs. Fore exampel use a spongebob teddy!! I have one of spongebob, it makes everyone laugh at the crag :)
Great idea! For my next one I was thinking of making a fur one with googlie eyes. Saw someone with one at my gym and couldn't stop smiling when I saw it!
