Introduction: Make a Compyooduh
Welcome, today you will be making a computer, behave.
Dear moderators this is a school project i promise im being good.
Step 1: Look at Components
Now is a good time to check and make sure you have everything, you should have at minimum a CPU, Motherboard, RAM, and an internal mass storage device.
Step 2: Install CPU
Make sure the triangle on the CPU lines up with the socket, you should feel little or no resistance. Otherwise gently try a different position.
Step 3: Install RAM
The notches must align since RAM only goes in one way. You may need to press firmly since RAM slots generally fit tightly, in fact if you have a loose fit you may want to check for damage or invalid parts.
Step 4: Add Thermal Paste
Carefully apply thermal paste, there is no standard pattern, and some coolers may already come with it pre-applied. If so skip this step.
Step 5: Install CPU Cooler
Install the CPU cooler by by rotating the pegs in the opposite direction of the arrow and firmly pressing them into the holes in the motherboard. After that connect the cooler fan to the CPU_FAN header or an equivalent connector.
Step 6: Place Motherboard in Case
NOTE: In this picture the other components are not installed, disregard this.
To install the motherboard place the standoff screws in their corresponding slots and tighten them firmly. The motherboard SHOULD NOT wiggle or shift in place.
Step 7: Install Power Supply
Please be sure to install all 4 screws fully and not pinch any cables. You will need an ATX power supply or a compatible adapter.
Step 8: Make Sure All Cables/ports Are Present And/or Connected
Make sure to seat connector properly and push them all the way in. A misplaced connector may cause the computer to
