Make a Desktop Zen Garden (Japanese Rock Garden)
Intro: Make a Desktop Zen Garden (Japanese Rock Garden)
There may be no better way to de-stress than by tending to your Zen garden. And hopefully making it won't be too stressful if you follow my simple guide.
This would make a great gift for a stressed executive, or parent for that matter ;-)
You'll need:
- A few lengths of wood, approximately 2' x 1½" x ¼"
- Some thin plywood, approximately 10" x 16"
- Two wooden cocktail sticks or thin bamboo skewers
- Wood glue
- Three nice stones
- Some fine dry sand (sandpit sand or similar)
I've entered this into the Homemade Gifts contest, so please vote if you like it.
STEP 1: Prepare the Sides
Plane, or sand, two lengths of wood, approximately 2' x 1½" x ¼" (each piece will make a long and short side) so that they are identical, smooth, and have squared ends
Divide each length into two pieces, on short and one long, using the Golden ratio (1:1.618). Roughly 9" and 15"
If possible, make a tiny rebate on one long edge of each piece, which will capture the base board. This needs to be the width of the base's thickness, by about 1/32". (Don't worry if you can't do this, any gaps around the edge later, can be filled with a mixture of sawdust and wood glue)
STEP 2: Jointing the Garden Walls
Finger (or box) joints make for a very strong connection, and are quite easy to make (below), but feel free to butt joint, dovetail, lap, or anything else
Finger Joint:
- Stack the four sides together (with the rebates aligned to the same side) and divide their width by four
- Square across the division marks, and drop them down the face by the width of the pieces
- Saw down each division
- Chop away two, non-touching, fingers for each piece
cont....
STEP 3: Jointing the Garden Walls (cont.)
...next:
- Transfer the finger lines from one piece to the blank end of the piece to which it will be joined to when assembled
- Square these marks down the face for the width of the pieces
- Saw, just cutting the line, down the face to define the matching fingers (most of the saw kerf should be kept in the waste portion of the wood, so that the finished fingers are a snug fit)
- Chop out the waste to reveal the fingers, and adjust to achieve a snug fit
- Repeat for all corners
Apply glue to the joint surfaces, assemble, and clamp
STEP 4: Base
Lay the assembled sides on top of the plywood, rebate down, and carefully mark out for the base
Cut the base out, and plane or sand until it fits snugly in the rebate (or just the sides if you didn't rebate them)
Apply glue to the edges of the base, insert it into the rebate, and clamp
Once the glue dries, plane or sand the joints smooth
STEP 5: Feet (optional)
To make the feet, first plane the remaining length smooth
Cut in a rebate of about 1/8"
Round over the upper rebate corner (face with the rebate facing up)
For each foot:
- Saw across the face of the main piece, with the saw tilted to create an undercut
- Saw a 45° cut across the face, to remove a right angle triangle from the main piece
- Saw a 45° cut the opposite way on the main piece
- Saw across the face, with the saw tilted to create an undercut, to remove a right angle triangle from the main piece
- These two triangles are then glued together to make a foot
Repeat three times for the remaining feet
Attach the feet to each corner of the garden with glue
STEP 6: Rake
You'll need a rake to make designs in the sand
Prepare a piece of the remaining wood to make the rake head, approximately ¼" x ¼". I leave it long for easier handling, and trim it at the end
Mark and drill for four tines and one shaft, using a bit that matches the diameter of your cocktail sticks
Cut four tines from one stick, and remove the points of the remaining stick to make the shaft
Glue the tines and shaft into the rake head
Trim the rake head for a symmetrical rake
STEP 7: Finishing Off
Apply a coat of finish (I used tung oil) and buff off if appropriate
Add a layer of sand
Rake, and add the stones to complete your garden
Thanks for reading my instructable. I hope you liked it. Please post photo's if you make one yourself.
Cheers, Mitch
3 Comments
Straklin 6 years ago
WOmadeOD 6 years ago
Thank you
Thanks
