Introduction: Make a Good Dupont Pin-Crimp EVERY TIME!
Anyone working with an Arduino, Raspberry PI, Beagle Bone, or any other multi-circuit-board project has become familiar with .025 X .025 in, square post pins and their mating connectors. The male pins are usually mounted to the circuit board with board to board wiring accomplished through mating connectors and wiring. These connectors usually consist of female pins that are individually crimped onto the wires which are then then inserted into multi-position connector shells.
These connector pins, also commonly called “Dupont Pins,” and are manufactured by AMP, Tyco, Molex, Samtec and a myriad of others.
Crimping Dupont female pins onto a wire requires a special crimping tool, precise techniques, and lots of time and patience! When I first started home-crimping these pins, I found that only about 1 in 10 came out right, with the rest defective in one way or another.
Thankfully, a few soles before me posted documentation, a few Instructables, and some YouTube videos that helped me get a started. Even at that, it took lots of trial and error and many crushed, damaged and unusable pins before I was able to get my failure rate under control.
Over time I studied my problems and came up with this guide and document to share some common crimp problems and solutions. In particular, you will see a very simple “Pin-Guide Tool” that you can make that will precisely position and hold the female Dupont pin inside of your hand crimping tool throughout the whole process. By using this Pin-Guide and a few other basic ideas, you too I can get a good crimp every time!
Step 1: Tools and Parts Needed
Above you can see the items you will need. Although not shown, a good wire stripper is also required. Take care in selecting and using the stripper as you will see soon, consistent strip length, free of nicks, is crucial to good Dupont pin crimp results.
Step 2: What Goes Wrong?
I studied my many failed crimps in an effort to figure out what was going wrong. I came up with the DEFECT TABLE shown above. This table helped me determine the root cause(s) for each defect which in turn, led me towards solutions.
While I don’t claim this list to be a 100% comprehensive, it does represent a good summary of my most common reoccurring problems.
Step 3: Wire Strip Length
The figure above shows the anatomy of a Dupont pin.It is seen that the total length of wire going into the pin should not exceed .2 in (5.0 mm). This means that when the wire is correctly and precisely positioned in the pin, the optimum wire-strip length is only 0.10 in (2.5 mm). A shorter strip length will compromise the conductor crimp while a longer strip length will either cause the wire to penetrate into the pin too deeply or lead to a degraded insulation crimp. For these reasons, I conclude that strip length is critical to achieving a good Dupont pin crimp.
- While I’m sure there are precision wire strip tools out there, I don’t have one. Therefore, I check each strip length and carefully trim away any excess wire whenever my stripped length is too long.
- As a reminder, take great care not to nick any of the conductors during the strip process as this will compromise the quality of the finished connection.
Tip: I found that recycled stranded-wire Ethernet cable is a good source for the interconnect wire.
Step 4: Pin Positioning Inside the Crimp-Tool
Improper pin-positioning within the crimp-tool tool was also a major reason for many of my crimp defects.
Perhaps I am just ‘all thumbs’, but once I thought I found the best spot to place the pin inside the crimper, I rarely seemed able to get it there. Furthermore, even when my pin placement was perfect, I frequently found that the pin would be pushed out of position or even rotated as a by-product of inserting the wire into the pin.
To solve this problem, I came up with a “PIN-GUIDE” tool. The Pin-Guide tool is nothing more than a strip of male pins onto to which the female pin to be crimped is placed. While simple, this Pin-Guide provides many benefits.
- The Pin-Guide provides a ‘handle’ for the pin so that placement into the crimper jaws is easier.
- The Pin-Guide precisely sets the position and depth of the pin relative to the crimper jaws. This serves to locate the CONDUCTOR-CRIMP zone and INSULATION-CRIMP zone in exactly the right spots within the crimp dies.
- Since the Pin-Guide ‘stays in place’ during the crimp cycle. it prevents the female pin from twisting, sliding, or moving while inserting the wire or performing the actual crimp cycle.
- The Pin-Guide also provides a ‘wire-stop’ that keeps the wire from going too far into the center of the female pin and obstructing the Mating-Pin Zone. Note that this fault only revealed when you find that you can’t plug the finished connector assembly onto the male PCB pins!
The Pin-Guide is easily fabricated from a 4-pin strip of male pins. The key to success however, is precisely setting the pin depth.
Step 5: Making the Pin-Guide
It’s easy to use the Pin-Guide. Just cut the female Dupont pin from the carrier and place it onto the Pin-Guide.
Step 6: Loading the Pin-Guide
Step 7: Selecting a Crimp Port
The SN28-B crimp tool has three different crimp-ports. Each port has a slightly different die shape and will form the pin differently. As noted in the figure, I found that I get the best results using “port 1” with wire up to and including AWG 22 Ga; I do not get good crimps with 22 Ga wire in position 2. Your results may vary however, as each crimp tool is adjustable; your setup maybe different than mine.
While the tool markings implies larger gauge wire may be used, I suspect that anything much larger than 22 Ga may not fit into the 0.1 inch spaced shells used for most Dupont pin connector assemblies.
Step 8: Loading the Dupont Pin Using the Pin-Guide Tool
As shown, with the female Dupont pin on PIN-GUIDE post #2, place the pin into the crimper jaws and close the jaws until they “click” and the pin is held in place. Be sure the pin is properly oriented and take care NOT to over compress the pin at this time as that will make wire insertion more difficult.
Step 9: Loading the Wire & Completing the Crimp
Next, carefully insert the stripped wire into the pin. As shown, be sure the wire is fully inserted and is not ‘hung-up’ during placement. While holding the wire in place, compress the crimper-handles to complete the crimp. Release and remove the completed crimp and perform a QC inspection.
After each crimp, it is important to perform a VISUAL INSPECTION as well as a QC PULL TEST of the pin-wire combination. A few examples follows that show you what to look for. Since the pins are small, I recommend you use a magnifying lens for all visual QC checks.
Step 10: Inspecting Your Work: Example A
Step 11: Inspecting Your Work: Example B
Step 12: Inspecting Your Work: Example C
Step 13: Loading Connector Shells
When the crimped pins are completed, they are easily inserted into the connector shells as shown. Pay attention to the photo details as pin orientation is important. Note that the pins will only lock-into the shell when inserted with the proper orientation.
Step 14: Summary of Pin-Crimp Steps
Step 15: Troubleshooting
As another aid to diagnose and trouble shoot common crimping issues, I offer the expanded trouble shooting table above.
CLOSING COMMENTS
This Instructable aims at helping you get solid, consistent Dupont pin termination results. I have focused on female-pins but similar steps can be applied to help you achieve good results for male-pins as well. I invite you all to review and tweak these ideas as you see fit to get them to work well for you.
Take care and Happy-Crimping!
53 Comments
6 months ago
This tutorial is great for female pins but the male pins do not seat as well on the stop. A close up photo would be nice to show which side of the pin goes in wich way.
Reply 11 days ago
I'm thinking 3d printing an attachment for the pin-guide to make it easier to handle. Seems like it might be easy to create a similar male connector guide using a female connector (or block of four) with a 3d printed sheath to position it correctly. I'm wondering if anyone has already designed something of the sort?
11 days ago
After nearly 20 failures, male and female, I was ready to give up, then I found this lesson. You saved me (from throwing my crimper kit in the trash). Thank you. Following this guide, my new record is 1 failure vs. 12 successful connections.
1 year ago
Very nice tutorial.
1 year ago
Thank you for taking the time to put this together. This is the best tutorial on Dupont Crimping i've found. It's helped me immensely.
Reply 1 year ago
Thanks for your comment; glad this helped you! Take care.
1 year ago on Introduction
Thank you Sir, Though a tedious process, its worth the effort to follow it exactly. I've followed other instructables for making dupont connections, so far this is the only one that works with any degree of quality every time.
thanks again!
1 year ago
I had to create an account, just so I could log in and post a comment on this. Thank you for this intuitive guide on making dupont connectors, and sharing your idea with the pin guide. I was about to throw in the towel on trying to make good connectors. Your guide got me going in the right direction! This is one of the best documented instructable I've ever come across. Thanks for taking the time to put this together!
1 year ago
This is one of the best and most organized and detailed sets of instructions that I have ever seen on any topic. Thank you! I have struggled to make good connections using Dupont connectors - this answers every question I’ve had, and throws in a handy guide tool as well. Great job!
Reply 1 year ago
Great! Glad you found it helpful.
Question 1 year ago on Introduction
Do you know how I can get some crimp connectors for tinsel conductor that penetrate the insulation? Martin
Reply 1 year ago
Sorry - I have no experience terminating or working with tinsel conductors.
Reply 1 year ago
Thanks for reply
3 years ago
Interesting article. When I had to replace a end stop wire on my 3d printer and add a JST connector I first bought an IWISS crimper (https://www.amazon.com/gp/product/B00OMM4YUY/). I could be wrong, but my estimation at the time was that it just wasn't sized properly for what I was trying to crimp. There are two different sized sections - one to crimp around the insulation and one around the wire - but the one on the wire side was too wide causing the pin sleeve to be crushed. I found the PA-20 crimper from Engineer Inc. (https://www.amazon.com/gp/product/B002AVVO7U) that only crimps one part (insulation or wire) at a time. I think that simplifies the issue greatly.
Reply 3 years ago
This is a pretty educational Instructable.
I've had the PA20 style since around 1980 and IWISS style for several years and done literally thousands of crimps on 1/4"~6.3mm spade terminals using 14 ~18 gauge wire without a problem, the IWISS style being slightly quicker to use. Because I'd had pretty good results I got the smaller IWISS style.
I found the same as you, the dies seem to be the wrong size and impossible to get a good crimp.I'll try adjusting them as I kinda like the way they work, holding terminals better with the locking ratchet compared to PA20 style
Reply 3 years ago
Hi. Good to hear you are doing well with the PA20 tool. I find that when I am crimping big spade terminals with a pliers-style, 'non-locking' tool, the quality of the termination is highly variable. I sometimes have to go back and make a second compression pass if the crimp seems 'loose' or incomplete. Worst case, I end up soldering the terminal as well to be sure I have a solid connection.
The locking-style crimp tool design came from the connector pin companies themselves. The logic behind them is that they are more 'operator independent'. That is, they only "unlock" after a complete crimp cycle has occurred and don't depend on operator judgement to determine when a crimp is 'tight enough'. This style of crimp tool only provides this assurance when 1) the correct-crimp-tool is used for the terminal being used, 2) a compatible wire is being used, and 3) the wire has been properly prepped.
In a prior life, I worked in a manufacturing plant making products that ran at very high current levels. Correct wiring was key to success.
Not only is the termination important, but all terminal block hardware had to be tightened to the correct torque specs. In these situations, a poor crimp or under tightened wire junction could lead to poor performance (ie: excessive voltage drops), and worst case, high temperatures and/or fires at defective junction!
Take care.
Reply 3 years ago
Hi. The pins I discussed in my Instructable were NOT JST connectors. I did a little more WEB research on JST pins and I agree with your assessment - the IWISS SN-28B crimper is not the right tool for "JST" connectors.
A quick search on eBay for a "JST CRIMPER" came up with the SN-01B crimper tool. On eBbay the tool is described as follows:
SN-01BM Crimp Plier Tool 2.0mm 2.54mm 3.96mm 18-28 AWG Crimper Dupont JST Molex .
This is DIFFERENT than the SN-28B. Take a look at the SN-01B photos as several show some of the pins as well. Are these the pins you are using? It appears to me that the JST connector is shorter than the ones I have used and referenced in my article. I can see that the SN-28B may mangle the pin. Also, the JST connector pin may have different strip requirements as well - You will have to check that out.
Good luck; hope this helps.
3 years ago
Well done. I followed your guide and just did 4 perfect crimps after many previous failures. Using a pin guide makes all the difference. Nice clear instructions and the pictures are great.
Reply 3 years ago
Thanks for your followup. Glad to hear it worked for you.
3 years ago
This was great. Thanks for writing it. I had my first attempt at DuPont cable crimping a couple of months ago. Eventually I got it to work well and I actually enjoy creating wires of just the right length. This guide would have helped back then. I am sure it will be a help to others in the future.
